03-21-2013, 12:49 AM | #1 |
carrier bearing question
i have to replace to carrier bearing in my 66 lwb c10 how do i figure out which bearing i have . my whole thing is shot rubber and all. please help. pics would help im chevy stupid.
03-21-2013, 12:53 AM | #2 |
60-66 Nut
Re: carrier bearing question
Is it the whimpy light duty one that hangs from the top of the trailing arm crossmember, or is it the 'D' shaped heavy duty one that sits on a plate on the bottom of the trailing arm crossmember?
Here is a pic of the heavy duty one.
03-21-2013, 01:02 AM | #3 |
Subscribed
Posted via Mobile Device |
03-21-2013, 02:01 AM | #4 |
here's a pic of the wimpy one...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
03-21-2013, 06:33 PM | #5 |
its the whimpy one now does anyone know the size measurement on it?
03-22-2013, 03:02 PM | #6 |
if you're wanting to put the same thing back in there, your local NAPA or auto parts store should be able to get it.
The NAPA here had one on the shelf. Just told them the year and model. It ran about $34 It makes for a good excuse to change out those old universal bearings too Posted via Mobile Device
'66 c10 LWB fleetside 250 I6 3 speed on column '65 c10 LWB stepside 350/327 3 speed hasn't moved in 10 years. Just rotting away |
03-22-2013, 05:48 PM | #7 |
Senior Car Nut
I don't believe it's just a matter of buying a HD one instead of the regular one either. for one thing, I believe the HD ones take a shaft with a slip joint. You really don't need to know the size, as Joe750 said. I've bought them 2 ways: complete with new hanger, assembled; and just the rubber/bearing. you're going to have to take the yoke off the rear of the front shaft to change the bearing out.
Larry |
03-22-2013, 06:01 PM | #8 |
thank you everyone now soon as it dries out down here ill be under truck .then its on to the next fix
03-23-2013, 12:25 PM | #9 |
Oh yeah, and I don't know how you're going to go about changing it... but your life will be so much easier if you take the whole driveshaft out in one piece and get it out from under the truck.
There's two small U bolts that connect it to the rear end. Remove those, unbolt you're carrier bearing from the crossmember, and slide then slide the whole thing off the tail shaft. Posted via Mobile Device
03-23-2013, 01:21 PM | #10 |
The carrier bearing will be sandwiched between the shaft and intermediate yoke on a short splined shaft. Definitely easier to do out of the truck...
03-24-2013, 12:02 AM | #11 |
One important thing to remember is to mark the middle yoke and the driveshaft tube before you take it apart, so it goes on the same position when you put it back together. You could put it back together out of phase, or in phase but 180 degrees off how it was when it came apart. It is balanced in the position it was before it came apart. Put it together the same, and there won't be any vibration or balance issues.
03-24-2013, 09:15 AM | #12 | |
Senior Car Nut
and, Woog, I think the HD one needs a rear shaft with a sliding yoke but I'm hoping Captainfab (or someone) will verify when they respond to your question
Larry |
