Old 03-21-2013, 04:17 PM   #1
belowme51
belowme51's Avatar
Thumbs up Check this out c10 addicts (MMW)
Hey guys,
Just wanted to share an experience I've had. Take the time to read this. I've been building a truck for some time now and had to make a change to my control arms due to tire/rim size, the control arms I had were perfectly fine for the application I had but I needed something else so the hunt began when I came across Michigan Metal Works. I spoke to Taylor there and he was always on top of responding to me and answering my questions which we all know does not happen much. This guy wanted my business, I could tell.
I have had my fair share of control arms and they are all about the same, they all could use some type of improvement or different components to make them better. MMW came up several times and the moment I seen their parts, how they were made and the quality and personal time involved with every piece I was impressed, plus they were not DOM like all the others there are flat plat super thick steel that you see in race trucks, some serious strength. To make it better the come with a Jeebus joint as the upper ball joint which gives you a ton of articulation which means less camber and less tire wear which saves us money in the long run. Plus the jeebus joints are super strong. I told Taylor what I was building and he knew exactly what I needed and they even make these to work with the awesome Porterbuilt Dropmember. They will powder coat any color and will even scout to match paint for the powdercoat to get you close as possible. The Jeebus joints are covered with a billet cover that will have their logo engraved or even you can ask to have something more personal like me as I wanted something special to include my wife with the build, and the hardware that is used as end caps for the bushings are also beautiful and well thought out.
At the end of the day Taylor and MMW are one of the best handmade control arm company I have ever done business with. They remind me of Nate at Porterbuilt with the care and the passion of taking care of each customers needs one car at a time, to me this means a lot. I just wanted to share my experience with MMW as they deserve it and if you are in the market for control arms or just about anything else like watts links, 4 link bars, custom spindles, and I'm sure more check these guys out please. MMW, Porterbuilt, and Accuair all paired up is going to give you nothing but the best as Taylor, Nate, Dave, Reno, and Derek have always been the best I have ever done business with. www.michiganmetalworks.com
or check out their facebook, don't forget to "like" their page but they have a ton of pictures, here are just a couple.
Thanks you again Taylor, You guys are incredible.
belowme51 is offline   Reply With Quote
Old 03-21-2013, 04:29 PM   #2
jimmydean
jimmydean's Avatar
Re: Check this out c10 addicts
I'm sure these arms have come up before. I think they are cool looking, but I have a thing for tube arms.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-21-2013, 05:49 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
They make some very cool products.
I have been following them for quite a while.
Plus they make arms and spindles for just about every vehicle you can think of.
If they don't have what you need,... I really think they would fabricate them for you.
Just recently started building some very unique spindles.
Check them out for 88-98, 99-06, and 07-up truck products.
They also build some cool a-arm set ups for tuckin big wheels up front on most dually trucks.
I'd really like to see Taylor on here more often.
Maybe even a Gold Vendor to add to our support vendor list here?!?
http://67-72chevytrucks.com/vboard/showgroups.php
(his username here,... is Jeebus)
He must be too busy building stuff.
Keith
Convert to disc brakes.
Old 03-21-2013, 05:54 PM   #4
belowme51
belowme51's Avatar
yes Taylor will pretty much find a way to make whatever you want happen, he did it with me and Ill post up some pics soon of this cool stuff.
Taylor goes above and beyond for everyone, plus he is a Porterbuilt and Accuair dealer.
some sik welds these guys put out also....
my arms with the v4 dropmember go perfect together to tie all the front flat pieces together plus the jeebus joints, well you need to check them out in comparison to a standard balljoint..you will be shocked!
They will make anything within their realm and will do anything they can to find a way to make it happen.
Old 03-21-2013, 05:55 PM   #5
lolife99
lolife99's Avatar
I think some of you will remember his last build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=448237
Keith
Old 03-21-2013, 06:04 PM   #6
lolife99
lolife99's Avatar
MMW also build these "Dodger" a-arms for 73-87 trucks that have modified crossmembers or z'd frames.
They help get that tricky steering shaft setup around you upper a-arm.
http://michiganmetalworks.com/store/...&product_id=79
These are the new “Dodger” series of upper control arms made for the 73-87 style C-10 Trucks. These arms do just what they are named after, they affectively dodge the stock steering shaft saving you hundreds of dollars in steering components and hours of work modifying your stock arms. These arms will install directly to your stock x-shaft with the new bushings and sleeves that are included with the kit, and will also accept the stock C-10 ball joints that are currently on your truck, or available at any parts store. These arms are designed to be used with stock frame trucks to dodge the stock steering on those trucks. If your frame is modified you will need to run a single joint at the top of your steering, depending on what size tire you are laying on.
The dodger arms are a product that is made ONLY by MMW, and provides a real solution to a problem that has made these trucks a hassle for a number of years.
Keith
Old 03-21-2013, 06:25 PM   #7
YBNORML
YBNORML's Avatar
Pretty cool stuff.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-21-2013, 06:54 PM   #8
belowme51
belowme51's Avatar
they rock.
I know the tube arms will always be popular because that's what most people know, and they can/have/will make DOM style but really defeats the purpose of what they do. These arms will take more abuse that you could ever throw at them, they are built for what you are building and let me tell you they are not afraid of a challenge.
If anyone has watched any SCORE racing or any of the desert runner style trucks that fly thru the desert or race dirt tracks drifting and jumping everywhere this is the style of arms they use. MMW arms are super thick and are really unique. We are all looking for a little edge to be different, this is the answer with many added benefits.
You want 24s on the front of your c10 they narrow and alter the arm as needed at no extra charge
There is nothing with tube arms as ive had them and some great one at that and they are great and will be best for some but the guys/gals looking for that little edge of being different with the performance that others don't have MMW is your answer.
They are fully dedicated to the execution of every part they make and then takes the time to make it only yours personally.
Sky is the limit on the arms if you want studs in them, a recess with insert, you name it and Taylor finds a way.
Like their facebook page and check out how many car clubs use their product. how many SEMA trucks use their product.....smoothster, reyna bros trucks, tre5 with some one off torsion bar lower control arms, etc...and the car club list is endless.
I think these guys deserve a lot more than a few thousand people to like their page. This is an industry first at this level of construction that is made for any project, price is great, options are endless with this many custom options along with a warranty like no other.
Just pure innovation and I am totally impressed with the personal expertise MMW offers, and the attention to detail and pride they put into everything they do plus there logo rocks!
Old 03-21-2013, 08:54 PM   #9
dv8customs
dv8customs's Avatar
I have MMW uppers on my project. Taylor makes a great product
dv8customs is offline   Reply With Quote
Old 03-22-2013, 01:20 AM   #10
andrewmp6
Taylor is the nate of the mini truck and newer truck world.He makes nice stuff that will take a beating.And makes stuff that no one else will like the 97-03 f150 to lay frame is a nightmare in the front.He fixed that problem with a raised upper a arm mount no one else has that but him.His no notch tie rod ends for the s10 and 88-98 gm trucks are another thing only he makes.
Old 03-22-2013, 01:40 AM   #11
ddubbs
ddubbs's Avatar
Man I've been looking at these lately. Was just on there website a few days ago. Arms look pretty killer!!!
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 03-22-2013, 10:07 AM   #12
Hart_Rod
Hart_Rod's Avatar
Nice parts.
Hart_Rod is offline   Reply With Quote
Old 03-22-2013, 11:02 AM   #13
SCOTI
SCOTI's Avatar
Re: Check this out c10 addicts (MMW)
I'm using his upper arms on my dually.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-22-2013, 11:58 AM   #14
belowme51
belowme51's Avatar
thanks for the kind words guys, lets get the word out there for MMW they deserve it. look see even SCOTI uses their arms on a dually...talk about durability. love it...
get to Facebook and like em up! go to their site and get some bad a** parts and thank Taylor for doing what he does as it is incredible!!
Old 03-22-2013, 02:24 PM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
His stuff it really cool. I enjoyed his build of the crew cab.
Jeebus has not been on here since 8/2/2012. He must be busy!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-22-2013, 07:41 PM   #16
lolife99
lolife99's Avatar
Here a new set of MMW arms for the 47-54 guys running an S10 chassis,...
Have a 47-54 Chevy Truck that you want to swap an S-10 Chassis underneath?
We whipped up a set of these conversion arms for a customer who is swapping a mid 90's S-10 Chassis onto a 47 Chevy body.
The arms push the wheels out to fill the fenders correctly and run an inboard shock to maximize your turning radius compared to stock arms.
They lay on 22s, with ease, and come with a steering kit to wrap it all up!
Keith
Old 03-22-2013, 10:40 PM   #17
chevyrestoguy
chevyrestoguy's Avatar
Wow! I'm very impressed. The quality looks top-notch, and I like the fact that they make unique pieces. Too many suspension companies all make essentially the same parts with very slight differences. Companies like MMW and Porterbuilt are the exception.
My '64 has a Z'd chassis and his Dodger arms would be just the ticket.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-25-2013, 02:08 PM   #18
meter swinger
meter swinger's Avatar
[QUOTE=lolife99;5964458]Here a new set of MMW arms for the 47-54 guys running an S10 chassis,...
I saw them post this on FB right after i had been measuring a jag IFS im about to put in my 59. Looks like this would make the s10 a viable option for 55-59 trucks also. Goddangit! These guys put new products out while im still sctracting head Guess ill punch s10 into my CL app.
meter swinger is offline   Reply With Quote
Old 03-28-2013, 12:53 AM   #19
blazins10
blazins10's Avatar
I have 3 sets of his arms ( 2-s10s, 63 c10 with dodger arms) and they are badass , ride great and are align able which is great for an aftermarket arms
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 03-23-2013, 02:12 AM   #20
67c10rustbuket
67c10rustbuket's Avatar
Never heard of them before. They do have some nice arms on their website. The dodger arms are pretty slick too!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 03-23-2013, 08:24 AM   #21
lolife99
lolife99's Avatar
Here's a pretty good view of all the stuff that MMW can do,...
http://www.facebook.com/#!/MichiganM.../photos_albums
Keith
Old 03-23-2013, 10:56 AM   #22
blazer2007
nice clearence for speed bumps ,I,m interested
blazer2007 is offline   Reply With Quote
Old 03-23-2013, 03:13 PM   #23
belowme51
belowme51's Avatar
Thanks again for all the cool feedback, love the pics really shows how great MMW product is! should check out Tre5's square body he is building with some really awesome MMW front end parts.
Old 03-24-2013, 01:01 PM   #24
808_67C10
808_67C10's Avatar
This is a first for me... Seriously debating a set for my 67 and for my 93 pre-runner! I have fabCraps on my 93... Not a fan.
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 03-24-2013, 01:21 PM   #25
lolife99
lolife99's Avatar
Contact Michigan Metal Works.
They can make whatever you need.
Keith
