1970 Daily Driver
Front clip Question - Is this out of a 1977 Impalla?
Had a shop do a front end alignment on the 56. It had a bad center link. He had to take the old one down to the parts store and finally found a match for one that came out of a 1977 Impala. I will attach my previous post that has pictures of the actual frontend.
Could this front end truly be out of a 1977 Impala? What kind of frame is this , an "GM A body" ? Are these a good fit for these trucks? Link to pictures ----> http://67-72chevytrucks.com/vboard/s...d.php?t=556179 .
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
![]() ![]() Join Date: Nov 2008
Re: Front clip Question - Is this out of a 1977 Impalla?
I can't answer the question definitively but I would think a '77 Impalaclip would be way too wide fora TF truck. They were still land yachts in those days. But I'd imagine a sub component like a center link could have been a part several vehicles had in common.
Posted via Mobile Device |
77 impala was a full frame car. Unless they cut the back half of the frame off, maybe it could have been used, but they were a wide boat.
Impala/caprice is a "B" body. Malibus, regals,montes and such are "G" bodys
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
1970 Daily Driver
Is there anyway of identifying this clip for sure by some type of part identification?
![]() Join Date: Jun 2011
A lot of the A body and Camaro suspension parts are the same. As others have said, the 77 impala is pretty wide. I just put a spindle off a camaro on my 77 El Camino. measure the traclk width. Camaro would be 60"-61" and a body would be around 64".
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
I just looked up the impala centerlink and it is not the same as the camaro or Elcamino (a body)....now that I think of it....an impala would be a b body platform....
I've looked at the pictures, but its hard to see. First off, what is this in? I see 56, but 56 what? Is it full frame? I have about 10 caprice/impala cars. If we can find some markings maybe i can point you in a direction.
![]() Join Date: Jul 2007
The 77 Impala was the first year of the smaller Impalas and Caprices and the tread width is only .2 wider than a 77 Camaro.
The 77 Impalas with the standard suspension had the 5 on 4-3/4 bolt pattern with 7/16 lug bolts while the ones with heavy duty suspension such as cop cars had the 5 on 5 bolt pattern with 1/2 inch lug bolts. Either is pretty good suspension and shouldn't be a reason for worry under the truck as long as it was installed correctly.
1970 Daily Driver
Mr48chev, are you saying that it could be a 1977 Impala clip? It does have the 5 on 5 bolt pattern
5 on five would be GM big car and from the looks of things I'd say 77 to late 80's Impala. The Nova/Camaro/Firebird and Chevelle front ends only came with 5 on 4-3/4 bolt pattern
five on five bolt pattern came with the bigger brake rotors and a bigger front sway bar most of the time. A lot of the GM front end parts interchange so you won't have trouble getting parts.
1970 Daily Driver
Would there be any vin codes on the clip I could reference?
1970 Daily Driver
I think they go from 77-88, right?
That is considered a "G" body car, right? I would have though a frontend from these cars would be to wide, guess not.
1970 Daily Driver
according to this link it is a B-Body that went from 77-96
http://www.spohn.net/?action=platforms Is that right?
