Old 03-22-2013, 06:28 PM   #1
cfan10
cfan10's Avatar
Cool No turning>gearbox>pix
Ok, decided to work on my truck today after...I really can't remember.
Anyway, I start it up and it won't turn without serious force as if trying to turn the wheel with it not running. I check the new p/s pump and it is bone dry, so I added fluid to the pump and it still won't turn easy. And the fluid comes right back out. None of the p/s lines are leaking.
The p/s gearbox has always had a small leak, but always worked fine. I look under the truck and there's a huge spot of p/s fluid?
What's really going on here? Is the box total trash now?
How much fluid does the gearbox need to work?
And as always many thanks.
http://i1294.photobucket.com/albums/...ps9ca6b278.jpg
http://i1294.photobucket.com/albums/...psb02c8ebd.jpg
Is this missing gasket really important?
http://i1294.photobucket.com/albums/...ps370ec868.jpg
1984 10 305v8/th350
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me.
Don't mess with my truck, my momma or my money...not necessarily in that order. ©
Stand for something or fall for anything.
[LIST][*]'98 Bourbon St. Brawl ©2010
cfan10 is offline   Reply With Quote
Old 03-23-2013, 11:02 AM   #2
cfan10
cfan10's Avatar
Re: No turning>gearbox>pix
C'mon guys, no advice?
Old 03-23-2013, 11:07 AM   #3
BIG V
Jack the front tires off the ground, see if you can turn them w/o he weight of the truck on them? Once you get them to turn it will take a few pints to " fill " the system. And the gasket is a seal to seal out grime from getting in to your pitman arm.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 03-23-2013, 11:51 AM   #4
mrolds88
After you put it up on the stands, Leave the engine off while turning lock to lock. Do that several times. Add fluid, repeat. Once level is up, then start. check it, then set down and try again. Should be good to go.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-23-2013, 02:31 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Just cut the belt. Been driving like a man for three years now
If your hoses aren't leaking then why is there a big puddle on the ground? Depending on how long it sat to leak that out of your steering box
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-23-2013, 04:22 PM   #6
cfan10
cfan10's Avatar
^The leaking is coming from the gearbox as soon as I add fluid.
Old 03-23-2013, 05:08 PM   #7
INSIDIOUS '86
Is it coming from the top or the shafts? How fast is it coming out?
Old 03-23-2013, 05:10 PM   #8
Sabaka454
Sabaka454's Avatar
If it's coming out of the gear box that fast just get a reman unit.
Sabaka454 is offline   Reply With Quote
Old 03-23-2013, 07:58 PM   #9
cfan10
cfan10's Avatar
Cool Re: No turning>gearbox>pix
Its coming from where the pitman arm connect to the box.
Old 03-23-2013, 07:54 PM   #10
cfan10
cfan10's Avatar
It is running out minutes after pouring it in the pump. Who has the best prices on rebuilt boxes? Any online stores?
