Old 03-25-2013, 07:56 PM   #1
truckster
truckster's Avatar
Battery Tray?
I decided that I would replace my battery tray when I pull the motor, since it's never been there. The PO had put a piece of plywood supporting the battery, and I expected the radiator support and fender would be totally rusted out.
I was surprised by what I saw; it really doesn't look too bad. I think I may only need the tray, something like this:
http://www.autoobsession.com/battery...hevytruck.aspx
It says it's a 3-hole mount, but I don't see where it mounts. Is it supposed to be welded in, or are there just bolt holes I'm missing?
truckster is offline   Reply With Quote
Old 03-25-2013, 08:04 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Battery Tray?
Where's the hole.Usually you can see the ground.They bolt in.The bolts are inside the batt tray on the outer panel and through the side into the core support next to the radiator.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-25-2013, 08:05 PM   #3
PanelDeland
Re: Battery Tray?
The one you showed welds to the sides you have in place.
Old 03-25-2013, 08:07 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Battery Tray?
For the price you can't go wrong. If it needs holes to mount it, you can always drill some.
I bought a complete battery holder for my 68 about 10 years ago but they were only about $30 back then. I noticed that they've gone up to $50 plus.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 03-25-2013, 09:51 PM   #5
truckster
truckster's Avatar
Re: Battery Tray?
Thanks, guys. I just ordered one. Some rust treatment, a little metal straightening, and it should be as good as new.
