03-25-2013, 11:05 PM | #1 |
Ignition switch has an instrument light?
Hello All I am installing a new ignition switch (original type) and I notice there is an instrument light housing on the switch. Is the correct? What is that light used for? I dont see how light can get thru the switch and be "seen"? THanks for any answers.
03-25-2013, 11:19 PM | #2 |
Re: Ignition switch has an instrument light?
Yes although most of them are burned out.
03-25-2013, 11:35 PM | #3 |
It lights the key hole through the tumblers. It was usually a deluxe option.
03-26-2013, 07:54 AM | #4 |
I had forgotten about that light until I read your post. It's still dark here so I went out in the garage and checked it. It isn't very bright but it does show you where to insert the key in the dark. As G&R said, you see the light through the key slot. I have the clear plastic bezel and it is also illuminated.
It uses the same socket and bulb as the dash lights so it's an easy "upgrade". |
03-26-2013, 12:13 PM | #5 |
Now I know what the extra lamp on the instrument panel was for, I always had an aftermarket ignition switch and this time its on the column. I repurposed it for one of the turn signals.
03-27-2013, 01:53 AM | #6 |
mine worked until a couple years ago. kinda nice actually.
