Fuel pump 454?
Heya guys / n gals
Does anyone know if I can run a 40gph fuel pump on a 454 with a 800cfm, 1406 edelbrock carb on my 454? The motor has a mild cam (RV cam) and long tube headers but thats about it. I've been narrowing down small issues trying to get my monster on the road. So any help would be greatly appreciated. Thanks
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Fuel pump 454?
just be sure to run a pressure reg but 800cfm sounds a bit much for the rv cam
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Feb 2012
Re: Fuel pump 454?
1406 is a 600 cfm carb. 1412 is a 800 cfm and 1812 is the 800 cfm thunder series.
Re: Fuel pump 454?
cool i was just going off what I was told. guess I should have done the research.
I have a 1406 and a 1409. so both are 600cfm correct?
Re: Fuel pump 454?
The reason I ask is all the pumps I have looked up for the 454 are 120gph. and the one I have on my 350 in my 85 is 40gph. both are 5-6psi. Ithats the only difference I can find between them. but the 120gph seems a bit much.
Re: Fuel pump 454?
bump
I built it
Re: Fuel pump 454?
i personally couldnt get a factory replacement pump to run the engine right. it would always run out of fuel after a few seconds of wide open. so i got the summit 110gph with a regulator set for 5psi and i can hold it to the floor all day and it does fine. edelbrock 1411 (750cfm) and "rv" cam.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
Re: Fuel pump 454?
Thanks bud that helps alot. Im gonna try something like that.
#9 | |
Re: Fuel pump 454?
Use a regulator no matter which pump you choose. Edelbrock carburetors are known to be sensitive to fuel pressure.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Re: Fuel pump 454?
ok I got the fuel issue taken care of. and now I got no fire. Damn it man. one thing right after another. She fired first time when I changed the fuel pump and the reg. saw a leak so I shut her down to fix it. And now nothing.... just spin spin spin..... AAAAAAAAaaaaaahhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!
My Carbon Footprint
Re: Fuel pump 454?
IF all you did was fuel pump, it's something simple. Wire wiggled of the HEI? Were you under the dash? Pull a plug and see if there is any spark. For any reason did you mess with the starter wires?
Re: Fuel pump 454?
I did find that my big starter wire has been chewed on by a mouse.... Grrr.
I do have spark at the plugs. I did the plug trick and it arc's real nice and pretty.... I still have flooding issues. Im gonna try another Carb. 1411 edelbrock.
