Light swithc wired wrong?
I have a 64 - when I turn my light swith clockwise or counter - it turns my rear lights from daytime to nightime setting - my dome light doesn't do anything - What the heck is going on here?
Re: Light swithc wired wrong?
It would be funny if your dome light comes on when you hit the brakes.
Re: Light switch wired wrong?
When mine was acting a little funky, I carefully took it apart and cleaned it out, made a world of difference. It's a simple design, I just made sure to keep track of all the little parts and how they went back together.
My truck ain't dead, it just smells funny. |
![]() Join Date: Mar 2012
Mine was doing some weird stuff. Ordered a new switch, installed and everything works like it should. Just a thought.
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
I would have to guess that A) either the switch is going bad or B) someone has jumped the tail light wire over to the panel light circuit. This is possible since the front park lights and the tail lights do not share a circuit in the switch, like later model vehicles.
Senior Car Nut
![]() Join Date: Jan 2008
MY guess would be tincan's option B. Melhilburn, does the wiring to the switch appear to have been messed with?
Larry |
I'm going to take a good look at it this afternoon - I would think it should be pretty obvious if the PO jumped the tail light wire out to the panel - Will let you know what I find.
It should look like this, the purple wire were move to one spot for the front turn signals to be on with the headlites thou, everyhthing else should be the same.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
