03-29-2013, 12:55 PM | #1 |
Bed bolt holes rounded out.
As it says they are rounded out and not sure what to do when going back together. I had to cut them off with a cut off wheel from underneath to get the bed off. One of the bolts had a phillips screwdriver slot built into the head of the bolt. These bolts only had 3/8 of a square shoulder to it where as my K10 had long square shoulders on them. I am not sure what or how to tighten the bed back down and it look correct. Any ideas?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
03-29-2013, 01:10 PM | #2 |
Don't Crush em Restore em
Re: Bed bolt holes rounded out.
You could just use normal hex head bolts the same length, the downside to that you will have the head of the bolt in the bed, something to stub your toe on.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
03-29-2013, 01:18 PM | #3 |
yeah, i rounded out 1 (thank christ!) when i took off my bed. it was a little time consuming but i built up the hole with my mig, then spent a while with a couple of chainsaw files to square it out. with Line-x on top, it's just like new. also picked up bolt kit from Classicparts for under $20
03-29-2013, 02:36 PM | #4 |
been here longer than Liz
You can get square hole washers. Weld those to the bed.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
03-29-2013, 05:55 PM | #5 |
I might have to look into that option. I need to figure out something before I paint the bed. Welding the washer to the top of the bed shouldn't be that bad but will raise the bolt up a bit.
03-29-2013, 06:15 PM | #6 |
I would do what Tx firefighter said. Although I would try and dolly the bent metal back into position prior to the welding. Are you doing paint on the entire bed? Or would you be spraying a bedliner in? If you were going the bedliner route, just weld in after everything else is painted.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
03-29-2013, 05:51 PM | #7 |
Watch out for your cornhole !
Drop a new bolt in and give it a single little tack weld.
Posted via Mobile Device |
03-29-2013, 09:35 PM | #8 |
