03-29-2013, 04:23 PM | #1 |
Need new wheels for a disc brake conversion
Hey everyone,
I'm going to do the drop spindle disc brake swap pretty quick here on my 63 C10, and apparently my factory 15 inchers wont fit over the calipers. Anyone know where I can get a new set of 6 lug 15 inch wheels that look like the factory steel wheels? Or close? I know that a GM 15 inch after 1970 was shaped different to accommodate a disc brake, but short of tracking a set of those down I'm wondering where/if I can get a new set. Been hunting around Coker and they have options, but they all seem to have many holes to fit a wide variety of applications.. I just want 6 holes.
There's barely any old skools on the freeway |
03-29-2013, 04:38 PM | #2 |
Re: Need new wheels for a disc brake conversion
I did the same setup and using the 70s-80s 4x4 rally wheels. They're 15x8 and 6 lug. Didn't put the tires on but believe with the 2 1/2 inch drop spindles and 1 1/2 coils cut I'll have to use a 245/60-15 tire.
03-29-2013, 05:44 PM | #3 |
Try using a 1/4" spacer before you buy new wheels. My '66 had been converted to disc and had the original tapered-barrel wheels still when I bought it. It was just a roller, not sure if there was enough clearance to allow for any flexing while driving.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
03-30-2013, 01:40 AM | #4 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by vectorit; 03-30-2013 at 08:49 AM. |
03-30-2013, 01:54 AM | #5 |
Are they 6 lug or 5?
03-30-2013, 04:08 PM | #6 | |
UCA63
Not too too hard to find either T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
03-31-2013, 06:10 PM | #7 |
Wheel Vintiques makes a '60's GM pickup rallye wheel that looks pretty sharp, but I'm not 100% sure they work with disc brakes. I fairly certain that I have seen them on our trucks with disc brakes and you can get them chrome or ready to paint.
03-30-2013, 02:15 AM | #8 |
meowMEOWmeowMEOW
Diamond Racing makes custom offset steel wheels in a number of "factory-ish" looks. They are fairly inexpensive since they are steel, and you can have them setup how you need them.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-30-2013, 09:07 AM | #9 |
They are 6 lug. My 66 is stock suspension right now. Changing it out starting this week.
Posted via Mobile Device |
03-31-2013, 06:29 PM | #10 |
67-72 parts collector,…
Look here for a good deal on 15x6 6-lug steel wheels.
$56.99 each. http://www.vintagetrailersupply.com/..._p/vts-545.htm I would ask them about using disc brakes to be sure,...
03-31-2013, 07:32 PM | #11 |
I wanted some what stock looking wheels after my conversion as well. I went with cragar deluxe 69s. They were only like 60 each through summit
03-31-2013, 09:20 PM | #12 |
Sounds like you don't want to search for factory wheels(?) - but they really are quite plentiful (i.e. disk brake steelies). Just let your fingers do the walkin (or your legs) in a few local junkyards - you are looking for 71-87 K10 or K5 wheels. They're 15" 6 luggers and clear calipers and fit factory hub caps. Rallies work also, as mentioned above, just depends on the look you're going for - but it sounds like you want steelies. It's worth doing the hunt for them. Or post a wtb on the parts board and you'll eventually be able to scrounge a full set. The money you save can be spent on powder coat then. Remember to grab 5 so your spare fits!
03-31-2013, 10:43 PM | #13 |
Here some 15x7 12 series smoothies bare medal and I had them powder coated..(Wheels Vintique) $49.99 through Summit and the shipping wont kill ya... and these wheels will clear the brake calipers
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
04-01-2013, 01:30 PM | #14 |
Thanks for all the great info and leads guys. This is a great board, there are some other places on the net that uhh, aren't as friendly...
Hey doobie, whats the backspace on those? I think I found the same wheel with a 4 inch backspace. Hows that fit?
04-01-2013, 11:16 PM | #15 |
The fit is perfect for me especially in the rear on a static drop...I like my wheels tucked inside the fenders... measured my side fender spare mount wheel and It looks like the back spacing is a little less than 4"..
04-01-2013, 11:48 PM | #16 |
Sounds good. I like mine shoved up in the fenders too. Thanks for the info.
04-01-2013, 01:36 PM | #17 |
Heres a pic of the factory steelies made for disc brakes found on 73+ trucks, blazers, 4x4s. You'll notice they have four bumps on the face to hold on the hubcaps, as opposed to the 3 bump drum brake rims. Im using them on my 63 when I do the conversion to disc brake.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-01-2013, 02:23 PM | #18 |
I have a pair of the rims you need in the parts section if interested ...
