Old 03-29-2013, 10:08 PM   #1
Bloodyjaws88
A leaf spring question.
Today, while looking under the truck, I discovered that the right leaf spring has a broken leaf. The 3rd one down is broke and has a 5 inch piece gone. The question is, can I reome the leafs, leaving just the upper leaf? I don't haul anything in the truck and am planning to swap to trailing arms at some point. I wouldn't think it would be dangerous by that's why I figured Id ask you guys. Thanks for any help or suggestions. Chris
Bloodyjaws88 is offline   Reply With Quote
Old 03-29-2013, 11:01 PM   #2
GOPAPA
GOPAPA's Avatar
Re: A leaf spring question.
It would be very dangerous if the last leaf broke as thats all that is holding the rear end to the frame of the truck .. not good wouldnt do it..
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 03-30-2013, 05:14 AM   #3
SS Tim
SS Tim's Avatar
At this point I would suggest a PAIR of used springs until you decide where you want to go with the rear suspension.
While you could remove the broken leaf from the pack the spring will not be right without it. There are also other factors like having to replace the center bolt and the fact that a leaf spring can be a dangerous component to disassemble without the proper tools and knowledge. Plus the springs need to match so if you alter one you need to do the other too.
SS Tim is offline   Reply With Quote
Old 03-30-2013, 07:00 AM   #4
jjzepplin
jjzepplin's Avatar
And for a moment lets think about where the missing piece ended up??? Please think about fixing this issue before driving it again. No need to to go down the freeway tossing large chunks of hardened steel at unsuspecting motorists...Just thinkin...DOH
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
