So got a problem. I have a 292 and she doesn't wanna run. So far I have replaced plugs, wires, cap and rotor, distributor, coil, battery, and rebuilt my carb. Anyone out there that might have had the same problem?
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
Re: 292 Don't Wanna Run
Fuel pump? You need to check some things before you start changing parts. I usually check spark first. Start with what's easiest for you. Then fuel. If you got both of those verify timing. Bring #1 piston to TDC on compression stroke and check position of rotor, pull dist. cap. It should be on #1. Did you just fill up the tank. You might have got some bad gas. Smell it.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). Last edited by airdale94; 03-29-2013 at 11:14 PM. Reason: add |
Fairly new fuel pump. And the gas is fresh. It could very well be timming.
What is the history of vehicle?, was it sitting for a long time or recently running? Look at the ignition system closesly, always use new points ( adjusted with right gap) and new a condensor to complete the tune up. These engines are very durable, you don't have to worry about timing chains slipping, these engines have timing gears and rarely fail.
Recently running. I've had the truck over 8 years, and proud to say that its my first vehicle. But it's never been street legal and it just sits. I do start it and run it every once in a while, cuz I've never had the money to put into it . So lately I've been fixing things here and there and now I can't get it to run. Its got fuel pressure and basicly replaced the whole ignition system and still won't fire up.
#6 | |
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
Does it start and die?
Just crank with no hope? Backfire or pop? Did you check for spark before your tore into it and replaced everything? Did you ever check for power at the coil? Run and cranking? How are you setting timing and point gap? Do you have a dwell meter? Was the condensor replaced? Spark plug wires in the correct firing order? Do you have a factory service manual?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
OK first lets see if you are getting spark. remove the coil high tention wire from the dist. Hold it near the engine & have someone crank it over, or use a jumper wire. You should have spark jumping from the wire to ground. If thats ok look down the carb throat & work the throttle linkage. You should see a squirt of gas each time. If not pour a little gas down the carb throat & try to start it If it starts then You have a fuel delivery problem. If you have no spark then you have a problem with the points or posibly current from the ign. switch or resister.
I went to move my 69 GMC that has a 292 yesterday , started on first try but then it just stopped ? Now I have same problem ? 12v at coil , plenty of fuel but no spark at plugs ? What should I check next ?
71 C-20 07 Magnum RT AWD |
Well found out that my carb is a piece of crap. I need a new one. I've got really good spark and good fuel pressure. So now anyone know of a good brand for a single barrel?
What carb do you have? Either a Monojet or a Model B. Either way, they are simple to rebuild, and a kit is like 25 bucks at the most.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Did you try pouring a little gas down the carb? If it starts , then it could be the carb. Does the choke work?
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
Dwell (points and condensor).
Mmm put some gas in it,Mmm fix me some mustard biscuits Mmm.Sorry couldn't resist.
Mmm.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#15 |
Ill get ya'll some pics today and see if I can find some numbers on this thing.
#16 |
here are some pics.
#17 | |
But yeah, check the filter where the fuel line attaches to the carb like Wrenchbender said.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#18 |
Just wondering if there should be an insulator under the carb,not just a gasket but an insulator,there's one on my 48 car and one on my 258 77 jeep cj,the one on the jeep is plastic,I think it's there to keep the base of carb from getting too hot...there prolly 3/4" thick...
#19 |
OK. That's a Rochester Model B. The B means that it is a manual choke. They are incredibly simple to rebuild. Here's a video:
http://www.youtube.com/watch?feature...&v=V2AINKEauVM You will be told that it is impossible to ID which model Rochester you have with out the little metal tag. While that may or may not be true, it don't matter. There are only 2 kits to chose from and the only difference in the kits is the accelerator pump. You will need to take the top of the carb off to see which kind you have. On one kind, the accelerator pump shaft stays round it's entire length. On the other type, the shaft is round at first, close to the cup, but then is flattens out. This has the flattened out one: http://www.carburetor-parts.com/Roch...-Kit_p_57.html And this is the round one: http://www.carburetor-parts.com/Roch...mp_p_1075.html Once you know which type you have, ask to see both kits that will be listed and see which has your type. The kits come with an assortment of gaskets, balls and springs, pretty much so it's the same kit for Model B or BC or BV, but it has to have the same accelerator pump.
#20 |
That carb has a filter behind the big nut that the fuel line goes in. It could be pluged up.
