reverse makes a loud bang
is it fairly normal for the reverse gear in a th350 to make a loud bang when it goes into gear? my stepdad's k20 did the same thing as my k10 but he did not have any problems with the tranny up til he sold it
Re: reverse makes a loud bang
Find out if the bang is from the diff or the trans
My freinds banged when he shifted into gear. More so in reverse. The spider gears and center chart in the diff were so warn they were about to let go. You can tell if you have a buddy look under and watch the driveshaft move a hole bunch when you go from D to R plus you hear it. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
sorry for bumping a old post but ya it was the rear diff after replacing it it does not shift near as hard into reverse
Check your u-joints in the rear end.... sloppy u-joints can make a nasty banging when going into reverse.
RIZ |
Yeppers, differential will do it. My truck is full-time 4wd, and it's my front diff that goes "clunk" when shifting into reverse.
I haven't torn into mine yet. Of all the things that could possibly be wrong in there (worn/broken teeth on the ring or pinion, bad spider gears, ect ect) is there any culprit that is more likely than others? It's a D44 front, and it's DEFINITELY clunking in the front diff. It's not a U-joint.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
Tags |
th350, tranny, transmissions |
