03-31-2013, 03:33 PM | #1 |
rear shackle/leaf spring issue
ok i just posted about this but i wanted to see if there was anyone else who could give me a hand here. i removed my old leaf springs got new and identical ones but when i took the old ones out the shackles were under a lot of pressure and instead of being on an angle they shot up to almost verticle so now it looks like my leafs are to short when i pry on the shackle it moves the leaf foreword but im still a tad short anyone got an idea of what it could be. heres some pics
Jeremy '86 GMC 1500 dropped 6" in the front and 6" in the rear 2003 Land Rover Discovery Low Life |
03-31-2013, 04:03 PM | #2 |
Re: rear shackle/leaf spring issue
sounds like the shackle needs to be loosened up a bit. my bolts in my shackles were seized tight! the 3lb mini sledge wouldnt budge them, but the grinder did. keep prying if your 100% sure the leafs are the same length!
*^MY BUILD STORY^* |
03-31-2013, 04:14 PM | #3 |
ya i might end up cutting the bolt off
03-31-2013, 04:26 PM | #4 |
Cut the bolt off and save yourself the headache better to use fresh hardware anyway and avoid the suspension binding up possibly and so it has full mobility
Posted via Mobile Device |
03-31-2013, 04:27 PM | #5 |
ya i think i will
03-31-2013, 05:20 PM | #6 |
is the leaf bolted to the axle in those pics?
bolt the leafs to mounts then jack up axle to leaf, also never tighten shackle until truck is on ground with wheels/tires under full load and then don't overtighten, remember that's a moving part
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-01-2013, 03:44 PM | #7 | |
One thing I didn't do is what you mentioned Jimmy (I always learn so much on this site). So, now that the truck is back on the floor, should I loosen/re-tighten the shackle bolts? I didn't touch the lower shackle bolts, so they should still be ok.
Project: 1980 Chevy SWB DD: 1999 Chevy Tahoe, lifted on 33"s Toy: 1996 HD FLSTC, custom by me |
03-31-2013, 05:30 PM | #8 |
No the axel isn't attached
03-31-2013, 06:50 PM | #9 |
Loosen the shackle bolt then, it should pivot freely
04-01-2013, 02:13 PM | #10 |
04-01-2013, 07:13 PM | #11 |
I always leave mine loose then jump up down in bed or bumper then tighten lol
Don't over tighten remember that's a moving part Posted via Mobile Device
04-02-2013, 03:26 PM | #12 |
Great advice - thank you.
