04-01-2013, 09:17 AM | #1 |
Tire size question
Hey guys I have a question about tires... I see lots of guys still running 15" rims in 8" width or so... what tires (size and brand) are you guys running?
I am running a 275 55 15... and they are too small (height wise) but I am not finding much tires that are summer/performance compound that are taller... can anyone help me out? I would like to stay close to the same width, but I want to be at least 28" tall tire
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
04-01-2013, 09:55 AM | #2 |
Re: Tire size question
275-60-15's would put you @ about 28" height (depending on tire mfr). BF Goodrich Radial TA's are still available & decent quality.
04-01-2013, 10:11 AM | #3 |
OK thanks for the response, are these tires a good tire for performance? I am taking off my bfg drag radials (they are way too soft!). anyone else have any suggestions? I
04-01-2013, 10:23 AM | #4 | |
If you're looking for a sticky tire for handling purposes, the BFG Radial TA is not it. These are decent quality street driving tires. There's not much available in 28" tall x 15" diameter as far as performance rubber (possibly some Hoosier autocross type of tire). Most performance rated tires are going to be 17" diameter minimum.
04-01-2013, 10:36 AM | #5 |
well, I dont want anything as sticky as those DR's were, but I want something inbetween a highway tire and a DR
something like a toyo proxy or bfg g force ta kdw
04-01-2013, 01:00 PM | #6 |
For any tire size questions just use this link and it will help a ton!
http://www.1010tires.com/Tools/Tire-Size-Calculator |
04-01-2013, 03:56 PM | #7 |
well I am not really looking to do size calculations... I am trying to find tires in that size... I am not finding many in that size (i want a summer/performance tire, not all season or off road tire)
04-01-2013, 05:06 PM | #8 |
I have used the Maxxis MS-2s in a 275 60 15 I was much happier with them than the bfg's ta's
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-01-2013, 05:16 PM | #9 |
The reason I have you that link is because you can put your size in and it will tell you all the calculations plus popular tires on that size. Also if you can't find anything than maybe you can play with the size and find what your looking for.
Posted via Mobile Device |
04-03-2013, 01:54 PM | #10 |
72 mario, where are those tires available from? i have never heard of them..
