HEI Distributor for 4.1L 6cyl
This months project is switching over to an HEI distributor. I'm on a limited budget and want to know if you have opinions about the set up I'm leaning towards:
- Cardone Remanufactured distributor for 1978 Chevy 4.1L - ACCEL Perform distributor cap and rotor kit - Duralast ignition coil I'm hesitant about buying an inexpensive eBay distributor and my shopping list is about the same cost as a Pertronix Ignitor II, so might as well get the real deal. Thanks for the input.
My truck ain't dead, it just smells funny. |
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: HEI Distributor for 4.1L 6cyl
You'd still be leaving the better system on the table, imo. Pertronix would be my choice.
Sam |
![]() Join Date: Oct 2006
I agree no big head cap, and easy as an ignition point swap!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
The truck will be my daily driver by summer, so my biggest concerns are reliability and gas mileage. I read a lot of threads about Pertronix and it's hard to separate fact from opinion. What pushed me away was Pertronix' website inferring the Flame-Thrower coil is needed to get full benefit of their product – which makes the HEI more attractive to my wallet.
If you have the Ignitor, I would like to know how long you've had it, if your gas mileage noticeably increased, and did you upgrade the coil.
Ive had mine for over 6 years and have had ZERO issues I did upgrade the coil but only becuse I had a MSD blaster coil . I did have to use a ballast resistor.
In the end it is your choice , and your $$. I went with the pertronix becuse : 1) easy install 2) It kept the "retro" look I wanted 3) No need to remove old distributor and mess with timming 4) the price was right HEI or pertronix either way you'll be happy with the upgrade.
I am running a Skip White HEI. I have put a advance kit in it and it has been flawless.
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
I run the Pertronix II in my 63 230L6, did upgrade to a stronger coil (Summit chrome coil, supposed to be an upgrade over stock coil), no ballast and has run flawlessly for over a year. Did see 1-2mpg better than the stock setup. Easy to install and fits nice under the stock cap.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Never Ending Projects
If you want one of the authorities of the Chevy Inline 6, Langdon's is the place. I bought my HEI (coil in cap style) from them.
http://stoveboltengineco.com/catalog...=0&sort=normal
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
60-66 Nut
I have not made the upgrade on a I6 yet, but a HEI designed for a 250 (4.1) 6cyl should drop right in your 250 6 cyl engine. You'll just have to change your wiring as per a typical HEI upgrade.
Watch out for your cornhole !
![]() Join Date: Jun 2003
The HEI is a drop in conversion. Yank the old stuff out, drop in new HEI, supply it with a good power wire, install new plug wires, and gap your plugs to .045. I've done it to every six cylinder truck I've ever owned.
You'll be very happy. They start, run, and idle so much better. Posted via Mobile Device |
#12 | |
