holy wire shortage...
I was charging my battey today turned around for a miniute when I got back out to the truck smoke was billowing out from the hood and seaping into the cab, i was literally gone for one miniute. There is a wire from the battery to a little box on the inside of the fender and from there to a harness with 4 or 5 other wires, and it ran to inside the cab. The wire was a thicker red wire. Under the dash is a mess of wires and i couldnt loacte where it went. Anyone have any ideas or suggestions???
![]() Join Date: Apr 2008
Re: holy wire shortage...
New harness.Don't risk your truck on 40 year old wiring.
What company has easiest/cheapest? I know they might not be the same...
Are there different harrness that I should check out or what? I have no idea about wiring...
A quick search came up with
LMC http://www.lmctruck.com/icatalog/cb/full.aspx?Page=160 Eckler's http://www.ecklerstrucks.com/electri...harnesses.html Summit / Painless http://www.summitracing.com/parts/pr...ckup/year/1970 Carolina Classic Trucks http://www.carolinaclassictrucks.com...g-harness.html EZ someone got on Ebay http://67-72chevytrucks.com/vboard/s...d.php?t=568201 M & H Electric Fabricators http://www.wiringharness.com/ VH Coachworks http://67-72chevytrucks.com/vboard/s...d.php?t=512511 or if you want to do it yourself color diagram http://67-72chevytrucks.com/vboard/s...d.php?t=185665 If I've missed anyone, please add to the list. |
![]() Join Date: Sep 2012
Man Im with the guy above, just go with a new wiring harness. You can go with american auto wire or painless wiring, I am sure others have opinions too but these are the ones I have heard of. You can do the whole truck for round 450. No need to lose a whole classic for that kinda replacement money.Anyone else??
![]() Join Date: Jul 2012
got mine from early classics. A little pricey but all the connections are already made. No cutting, splicing, or crimping. Just plug it in and go. Im not sure of the manufacturer of them. Call ECE and ask for Stan
When I restored mine I was looking at different options for a harness. All of the per-built harness were (In my opinion) too expensive so I started looking a just buying wire and connectors. I was shocked at just how much copper has gone up in price so I looked on Ebay. I purchased a good used harness from a 1995 Pontiac Trans Am. It was the complete harness from bumper to bumper for $60.00. I was able to wire the whole truck and also use the newer fuse box and some of the connectors and I still have lots of wire left over.
I've heard good things about American Auto. Unfortunatly not untill after I had mostly installed a Painless harness. FYI, "Painless" is just a name and has NOTHING to do with the install. I had over 40 hours just under the hood and front lights. Definitely get something that already has all the connectors on it. Plug-and-play!
It is a well-kept secret that all electronics work by smoke not voltage difference. Once you let the smoke out, they don't work any more.
Seriously, once you have had smoke and melted wires it is best to replace the harness. I have seen the results of electrical fires that turned into house fires and it is not pretty. I have used the "streetrod" sytle harness and I would much rather use a factory style with factory ends if at all possible. It will be more expensive up front, but you will save installation time and will have a better resale. The only time a streetrod harness makes sense to me is in a race car or heavily modified (no factory switches) type installation.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Jan 2011
I have a complete harness out of a 69 SWB stepper you can have free if it will help you. Just pay shipping on it and I'll send it to you. Even if you used parts of it, it might be a direct swap over (not sure what kind of truck you're working on) .. LWB I'm thinking might be a bit different but .. it's here if needed. Just PM and I'll make arrangements to get it to you.
CC69RAT that would deffinatly help! I have been discouraged lately after my incident, looking at the prices of wiring harnesses. Plus i look at the wiring diagrams and am kind of lost. I have a 1970 C 10.
SWB or LWB ? This one came out of my SWB stepper .. but I think it's the same from the cab forward. (?) Someone might help us out here. It's pretty solid and uncut.
PM me your address and I'll get it to you ..
#14 | |
bblank79-It sounds to me like you might have fried your voltage regulator. Your voltage regulator might have been bad to begin with (Why were you charging the battery?)
http://www.truckandcarshop.com/trucks60_72/t60_100.html
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
#15 |
sounds to me like you hooked the charger up backwards to cause damage like u described
#16 |
tell you what .. shipping on me bro. All I need is your address. If you're not making mistakes, you're not learning, .. just how I see it. Whatever happened, I bet you wont do it again. This harness is just laying in my basement, not doing anyone any good. It's yours.. just let me know where to send it.
#17 | |
1970 SWB Build |
#18 |
![]() Join Date: Nov 2011
Good on CC69. I have a harness out of a 72 as well if you need the long bed tailight portion. PM if you want it no charge.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
#19 |
made my own. much easier as I can change the length of wires without splicing. it just takes a bit more time.
#20 |
I could use the harness if you don't mind and he doesn't need it. That's one of the things I need to take care of. The P/O pulled the V8 and put in an inline 6. As you can see in my pic, it's not good. It also has a short somewhere, draining the battery. That's why I had a list of companies that do harnesses. It will be a while before I can afford a new one. I'm on a medical leave from a tumor removed from my spinal cord last July and insurance gets the bills paid and not much else.
#21 |
Either way .. It's here if you guys need it. I'm doing an aftermarket harness in my truck so I'm not going to be needing it.
All I ask is PAY IT FORWARD ![]()
#22 |
Its a 70 LWB. I was chargimg my battery because there is either a short that is draining my battery or for some reason my alternator isnt kicking on? When i got the truck the battery cables were reversed, so I DONT think I was charging it backwards! is there a way to tell if the voltage regulator is bad, it brand new only a few months old? Thanks everyone for the advise and help!
#23 |
Autozone can test it for you, I worked for them a long time ago.
#24 |
Brian, Ill be at my Pops place on Sat. Ill box it up and get it on the way to you. I hope it works out, just use whatever you need, or even swap out the whole thing (?). Its pretty clean as far as I remember. Not hacked up as I recall.
#25 |
Hey man dont give up on this board, there are tons of good people on it willing to help for every 1 schmuck that just wants to berate people and probly doesnt even have a truck. Its a great place here and full of good people, if I ever see anyone in need and can answer questions I do it and so will many many others. Dont give up fella!!
