Old 04-01-2013, 10:50 PM   #1
msg
Alternator Bracket advice on 66, 350 with PS
I am looking to either replace the bracket I have or understand how to adjust it properly. I had a belt that was squealing bad and tried to change it and dang that aint easy with this bracket I have. Normally they loosen at the base to pivot and on the top brace to tilt towards the fan to loosen..not this one the body of the alternator is already right up against the bracket so it cant tilt inward.
So I had to remove 2 bracket bolts to the motor to get it to swing forward and removed the belt. I bought a new one and tried to install and it sounds worse than before because its not aligning properly to the fan pulley.
Geezer#99 has been a great help and passed this bracket along,
http://www.alangrovecomponents.com/S...Short_Pump.htm
I need to check on whether or not it will work with the power steering I have.
Any others anyone can pass along?
Here is the closest Ive gotten to being aligned
Shots of the bracket I have
msg is offline   Reply With Quote
Old 04-01-2013, 11:10 PM   #2
akaupp
Re: Alternator Bracket advice on 66, 350 with PS
On the 3rd pic, can you shim the front bolt (the one to the right) between the 2 parts of the bracket?
akaupp is offline   Reply With Quote
Old 04-01-2013, 11:27 PM   #3
msg
Yeah I put 3 washers in between that part of the bracket but the tension still distorts the alignment. Maybe a slightly larger belt?
Old 04-01-2013, 11:31 PM   #4
akaupp
Might be worth a shot, I think I used 15xxx belts on my 49 that had the same style alternator bracket. It never made any noise, although it wasn't very happy at 8k rpm...
Old 04-02-2013, 01:13 AM   #5
Captainfab
60-66 Nut
You have a mismatch of parts there. With the alternator on the drivers side, the belt should be on the crank pulley right up against the harmonic balancer, and of course the corresponding water pump pulley groove. The alternator being so far out is exerting too much leverage on those lower brackets, and likely will never be solid and not move. Of course this is assuming that you have the short water pump as should be on your engine. Some more pics of your pulley setup and water pump would help get this figured out.
Old 04-02-2013, 09:21 AM   #6
msg
I tried replacing the belt with a larger size but went too far, wouldnt fit too loose. The pic shows the progression of belts so far. The bottom one was the origianal that was screeching, the middle is the 2nd try a bit longer and wider for maybe a better grip but was still too tight , and the last one is too big. So I'll go the parts store and buy a few more in the mid range between the middle and top one.
And here are some additional pics of the set up Captainfab, hope this helps. Let me know if it doesnt. Thanks.
Old 04-02-2013, 11:50 AM   #7
padresag
the Capt is right that the alt belt should run on the inner pulley. the p/s pump should be out further. the p/s pump is for a long w/pump
your w/pump pulleys do seem a little different to. what does the crank pulley look like.
looks like somebody cobbled the setup together to make a short w/pump work on that engine without the corresponding parts
ron
padresag is offline   Reply With Quote
Old 04-02-2013, 12:44 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
ron
Ron it looks as if he has a long water pump....?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-03-2013, 12:18 AM   #9
Captainfab
60-66 Nut
Those pics confirmed what I suspected. You have a long water pump, with a drivers side alternator mount which is designed for a short pump. I have no idea what sort of PS pump mount you have that someone cobbled together. I see stacked spacers and nuts. One problem you are going to have is that the OEM long water pump accessory brackets require the heads to have the accessory bolt holes, which your heads do not.
One way to fix your situation is to change over to a short water pump, pulleys and brackets. That is what these trucks came with from the factory. The pic that Rich 5150 69 posted shows a short water pump with the correct pulleys and brackets. If you feel you need to keep the long water pump, then I believe Alan Grove may have some brackets to help you mount your alternator and PS pump more solidly. With what you have there now, I doubt you will ever have a reliable, trouble free accessory drive.
Old 04-03-2013, 02:31 AM   #10
414banger
414banger's Avatar
for what it is worth i had the same problem with alternater positioning since i have the pre 69 double humps with no holes so i called alan grove coponents up and got a mid mount alternater bracket that goes on the passenger side the thing fits real nice i havent got around to the power steering yet but when i do i will call them again for the bracket for it
1965 c10 sbw longbed fleetside
350 bored .60 over th400 tranny
lowered 4/5 static
414banger is offline   Reply With Quote
Old 04-03-2013, 09:09 AM   #11
msg
Thanks for the info guys, I will Alan Grove a call and see what can be done.
Some history on the cobbling, I had the power steering added in January 2012 by a fella that mentioned that he had done that conversion before with 1973-1982 model junkyard parts gear box, power steering, lines and pulleys and aftermarket conversion kit.
Here is the breakdown that totaled $587
Salvage yard
From a late 70's Chevy Pickup I think?
Gearbox, Power Sterring, lines, and pulleys =$125
Classic Parts
Power Steering Conversion Kit = $60
Pitman Arm = $50
Custom Shop = $402
Install custom power gear box and pump
make brackets (which I think included the alternator bracket to the motor)
new belts
New fan since the original didnt have the right bolt config
new heater hose
weld steering rod
new coolant
For all of the years before I had driven this truck without PS this seemed like a bargain to me. Wish I would have found this site before, live and learn.
