Receiver Hitch Question 61 Chevy
I have a 61 Chevy Truck and of course...there are no bolt in, off-the-shelf hitches for this truck due to the wider rear frame width. (Just like all the other things that you can't buy for the 60-62's)
I plan to hang some brackets off the bottom of the rear frame (2 1/2" X 6" X 8" X 1/4" metal), and use a 2" tube (37" X 2 X 2 X 1/4" metal) as the cross member. I'll cut holes in the side brackets so the cross member tube can slide through the brackets and get welded up on both sides. Then I'll weld up a receiver hitch tube to the bottom of the crossmember and add some additional angle iron bracing as a back up. Question - my dad says that the frame on the back of the 61's is not going to be strong enough to hold a Class III Hitch and the associated weight from a trailer from the bottom. He wants to brace the frame up from the inside and along the bottom rail. Does anyone have some ideas on this matter? Is that necessary? Or, do you have some ideas with regards to how I could brace the frame up a little bit more? Also, I do have a rear, under-bed tank behind the axle and between the rails if that helps. Thank you Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
Just here to tinker
![]() Join Date: Jun 2008
Re: Receiver Hitch Question 61 Chevy
The frame is plenty strong enough. I bought a universal hidden hitch for an rv, bolted it up and welded in place. Never had any problems. I'll see if I can find you a part number.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
either that or find a used one for the 34" frame and just replace the square tubing that joins it all together. not everything has to come off the shelf.
ron |
