04-04-2013, 07:09 PM | #1 |
Tot Roddin'
'69 Manual Master Cylinder (Disc/Drum) Bore Size
What would the correct bore size be for a 1969 pickup with a manual disc/drum setup?
Also, what master cylinder would you recommend for this setup? The individual is looking to cleanup under the good and would like a proportioning valve mounted up under the master cylinder.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-04-2013, 07:40 PM | #2 |
Tot Roddin'
Re: '69 Manual Master Cylinder (Disc/Drum) Bore Size
I believe it's 1" bore iirc.
04-04-2013, 09:41 PM | #3 |
67-72 parts collector,…
1" is what I would use.
Aluminum only!
04-04-2013, 11:16 PM | #4 |
Based on what I have researched, these trucks only came with 1 1/8 bore for manual and power disk/drum. Most people, myself included use a Corvette master, which is a 1" bore. POL has an aluminum Corvette MC and the prop valve can be mounted under the MC or to the side like factory.
Posted via Mobile Device |
04-05-2013, 05:24 AM | #5 |
Tot Roddin'
Thanks for the info.
He just located the CPP version with the built in proportioning valve. So we'll see where we end up. Posted via Mobile Device
