Old 04-04-2013, 10:51 PM   #1
nitrosport_5
nitrosport_5's Avatar
Rear Paint Divider Install Question
Im looking for any tips on installing the rear paint divider on a truck that was not originally equiped with the molding. id love to use the original type studs if possible. What are they called and where are they available? Thanks in advance.
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 04-05-2013, 12:30 AM   #2
Lee H
Lee H's Avatar
Re: Rear Paint Divider Install Question
Most of the after market vendors have a kit for the divider trim. It consists of small screws and plastic clips. I installed the screws in the factory stud location, clipped the plastic clips over the screws, and then installed the trim (top on first then push down). Have never seen the studs in the after market.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-05-2013, 12:52 AM   #3
SS Tim
SS Tim's Avatar
Don't think there is an easy way to do it. The factory repair was screws as are the kits available. We would mostly use pop rivets instead of screws when adding divider trim for a vinyl top.
Why would you want to go th the effort? Once the trim is in place they wont be seen. If you are worried about moisture intrusion then go with the pop rivets and use some sealant during installation.
SS Tim is offline   Reply With Quote
Old 04-05-2013, 04:11 PM   #4
cheyenne shortstep
cheyenne shortstep's Avatar
Any body shop should have a stud welding gun and the attachment to weld the OG style studs, I have done this with missing window molding studs ( I have the gun and studs) upon the anal customer request. Way more work than it's worth, use the screw/pop rivet method and be done with it.
cheyenne shortstep is offline   Reply With Quote
Old 04-05-2013, 04:24 PM   #5
nitrosport_5
thanks for the response. I'll just pick up the kit with screws and save the trouble
Old 05-19-2013, 11:13 PM   #6
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
My 72 GMC has 1 side rivets and 1 side screws. How do the plastic clips go on? Its been a while since I took it off. Forgot how they go on.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-20-2013, 12:21 AM   #7
leddzepp
Moderator
leddzepp's Avatar
They go over the head of the stud, and slide and lock into place. The trim snaps onto them very easily and snug. Here is a pic of 2 OEM clips
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-20-2013, 02:23 AM   #8
nitrosport_5
would you happen to know the size of the screws to use ? I bought the clips but need screws. I figure they have to be somthing available at an auto parts store or hardware store.
Old 05-20-2013, 08:36 AM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Same here. Like I said 1 side of my cab has rivets the other doesn't.
Old 05-20-2013, 09:57 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Here is a thread where I was installing the clips & trim on my Red/White '71. It already had the studs on it though.
http://67-72chevytrucks.com/vboard/s...d.php?t=333478
LockDoc
Leon
Old 05-20-2013, 10:34 AM   #11
Lee H
Lee H's Avatar
Here's a picture of the screw, I bought these from Mar-K.
Old 05-20-2013, 12:51 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ya. I finally found that. Thx.
Old 10-07-2014, 05:06 PM   #13
j carter
How many screws you need and what are the measurements
j carter is offline   Reply With Quote
Old 10-07-2014, 05:36 PM   #14
JointTech
JointTech's Avatar
my truck came with sheetmetal screws holding the trim on. custom touch. corvette option.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
