Old 04-05-2013, 02:27 AM   #1
murdoc3
Drive Shaft Replacement?
Can anyone point me towards instructions on how to replace a driveshaft in a 1964 Chevy C10 Longbed? It has a 350ci V8 + TH350 Auto Trans. I also have the 1963 C10 shop manual but I'm not seeing anything in there regarding driveshaft replacement.
More background:
Currently whenever I try and put the truck in gear I am getting a very loud grinding noise and my neighbor was visually able to tell me that something was wrong with the driveshaft. Now I just need to get it out and have one fabricated (or have this one rebuilt)
Thanks in advance.
murdoc3 is offline   Reply With Quote
Old 04-05-2013, 02:38 AM   #2
murdoc3
Re: Drive Shaft Replacement?
I should also mention that its a 2pc driveshaft.
Old 04-05-2013, 05:22 PM   #3
murdoc3
Thank you Woogeroo!
Old 04-08-2013, 04:50 PM   #4
murdoc3
I managed to get the drive shaft off successfully this weekend.
As far as I can tell the center carrier bearing it toast and the slip spline (not sure if that is the right term) appears to be sheared off the 1st part of the drive shaft where it meets the 2nd part.
I took it to a repair shop and they want ~$600 to repair it.
Anyone know if this is a good deal? Would it be better to just get a new one?
Old 04-08-2013, 05:27 PM   #5
Rich 5150 69
Rich 5150 69's Avatar
Is this a drive line repair shop...? seems to be way over priced...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-08-2013, 05:50 PM   #6
murdoc3
It is a drive line repair shop.
Old 04-08-2013, 07:48 PM   #7
slepysal
slepysal's Avatar
yea thats way up there. Call South Bay Driveline in San Jose
(408) 995-6000
See what they can do for you
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-09-2013, 03:48 PM   #8
murdoc3
(408) 995-6000
I called South Bay Driveline. They said they could replace my 2 piece with a 1 piece for $375 or they could build me a new 2 piece for $600.
Old 04-09-2013, 03:53 PM   #9
65c10restomod
I dont think your drive shaft should be moving if your setting still or was the truck moving when you hear the grinding noise
65c10restomod is offline   Reply With Quote
Old 04-09-2013, 02:13 AM   #10
murdoc3
Thanks! I will give them a call in the morning.
Old 04-09-2013, 06:04 PM   #11
murdoc3
thebobbykey I believe the grinding noise was from metal on metal rubbing vibration where shaft was severed.
Old 04-09-2013, 02:32 PM   #12
murdoc3
Originally Posted by Woogeroo View Post
You may want to pick up the 1964 Supplement, shop manual to. It covers any changes... which were many.
The shop manuals have the information under: propeller shaft
in the 1963 manual look in section 4, around page 4-98
on page 4-103 is a nifty diagram.
Lots of information all through that section there.
If you have a digital camera, snap a few photos of what exactly is broken on the "propeller shaft".
-W
Thanks again Woogeroo. After you sent out the initial link I pieced together that the drive shaft is also called a propeller shaft and from there I found the info in the shop manual.
