04-05-2013, 12:45 PM | #1 |
What do you think of this exhaust
I have a 79 stepside with Hooker 2452 headers
http://www.jegs.com/i/Hooker+Headers/520/16523/10002/-1 Will these fit my short bed? And why do they say this exhaust fits my headers? Headers are 2.5" exhaust is 2.25" Wanted an X pipe how hard would it be to add one? Thanks
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
04-05-2013, 12:57 PM | #2 |
Re: What do you think of this exhaust
The headers may be bigger but the exhaust has a neck down section.
If you want an x pipe system pypes makes one about 2.5 and 3" pipe diameters but expect to pay double You can just add an h pipe and get very similar results though It's a good kit. I may get it for one of my trucks Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
04-05-2013, 01:11 PM | #3 |
I used that kit on my 81 swb with a summit h pipe kit. Fit good I put it together with summit band clamps rather than the supplied u bolts.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
04-05-2013, 01:36 PM | #4 |
Check out the site vendors here for captkaos. He has a stainless kit made up that he sells for a 4x2 shortbed. Or check out this link for universal x pipe kits from jegs. http://www.jegs.com/webapp/wcs/store...ance+Pipe+Kits
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
04-06-2013, 08:12 AM | #5 |
Is it really worth it to put an x pipe in? And will that hooker exhaust fit my short bed?
04-06-2013, 09:42 AM | #6 |
IMO the x pipe may be hard to put into the hooker system due to the difference in the bends in each side. The h pipe i put in fit fine. Yes I have a short bed and it fits fine. You just cut the piece of pipe to length that goes between the muffler and the tail pipe.
04-06-2013, 08:19 PM | #7 |
What about a 2.5" set of pipes. Where is good place look for that
04-10-2013, 01:26 PM | #8 |
Here are some installed pics of my system to give you an idea of what I was saying about the X pipe.
Exhaust I used http://www.summitracing.com/parts/hok-16523hkr
04-10-2013, 03:06 PM | #9 |
Magnaflow did a test a few years back and showed that they received better numbers with an H pipe than with an X pipe, but both were better than stock. I used an H pipe on my setup. You get better exhaust flow and even sound distrubution with both. Also helps you hear the cam separation. As for fitment, the bolt flange will be the same on both sides. Pipe size doesn't matter. My collectors are 3.5", but my exhaust is 3". If you have any local exhaust shops, they are usually the best place to look.
V.P. of The American Squarebody Association. 1982 Sierra, 555 BBC, All Billet 700R4, Fab9 with 4.11's, Full 8.5 cert cage, 31x18x20 MT Sportsman S/R's on custom made 20x15 Amer. Racing Hopsters, 4-link with anti-roll bar and dual adj coilovers, Front drag shocks, Custom interior, and quite a bit more. |
04-10-2013, 09:23 PM | #10 |
Call me crazy, but I like a dual exhaust with the sides unconnected. To me, the sound just has more of a thump to it and I like the "stereo" sound you get. I've had several different exhausts with and without H pipes, and every time the system was without an H pipe the sound just did it for me.
It all boils down to personal preference though. I say just run whatever sounds like music to your ears and puts as smile on your face, that is the exhaust that is truly worth it.
1977 GMC Sierra Grande |
04-10-2013, 09:34 PM | #11 |
I awalys run a 2 into 1 deal. My latest setup has Doug's tri- y longtubes, Flowmaster 2 1/2 spun cats, dual 2 1/2 to single 3 inch Magnaflow collector, single 3 inch flowmaster muffler and 3 inch tailpipe.
It's compact, tucks neatly between frame rails and sounds incredible. . Posted via Mobile Device
04-11-2013, 10:39 AM | #12 |
78K & 79C Jimmys
my 78 4X4 useing walker setup could fit a H in there(had tails,not anymore)
my 79 4X2 "Speedy" custom bent 2.25 with a 2" H (sounds awesome) I'd get it in,then get a shop to make the H after?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
05-19-2013, 07:00 PM | #13 |
Chris here's a couple of pics of the right side near the trans cross member.
