04-05-2013, 04:52 PM | #1 |
350 trans stock column
I have a 350 trans and a stock shift on the tree steering column for an automatic transmission that is not hooked up. How well will this work if I connect them sense the original trans had one less gear? Will I be able to tell if it is in the right gear?
04-08-2013, 04:36 PM | #2 |
Re: 350 trans stock column
Com on. I know some body out there has an answer for me.
04-08-2013, 04:46 PM | #3 |
Original auto trans would have been a 2 speed powerglide. Im a manual trans man myself, but Im sure the auto trans guys will chime in. I know that there are several aftermarket coumns available, but sounds like you want to retain the stock column?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-08-2013, 05:22 PM | #4 |
People here in he past said it works fine in the drive position, but I don`t know whether you can grab the L-1 / L-2 position....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
04-09-2013, 08:00 AM | #5 |
It will work fine, you can get all three gears just when you go to 1rst it won't show on the indicator. All other gears display correctly
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
04-09-2013, 08:45 AM | #6 |
I have a 700r4 with a 91 tilt wheel, no indicator at all and I do not have any trouble telling which gear the truck is in.......Kieth
