Oil and Volts hookup?
Does anyone have a good place that explains how to troubleshoot the Oil pressure gauge not working, like where the sender is located? And also how the volt meter is supposed to be hooked up as well.
I have an 87 Chevy 1/2 ton 4x4 with a 350. The truck book I have really sucks and doesn’t have it anywhere in it that I can find. Thanks! BB |
It followed me home?
I am having the same problems, hope some one can help out
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
LED King
A dead oil pressure gauge is usually the sender. It is kinda under and behind the distributor. If you take off the cap you can get to it. Voltmeter not working is just a dead gauge usually.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
You get what you pay for
![]() Join Date: Dec 1999
In 87, the oil pressure guage is probably right above the oil filter. The up on top beside the distributor is a switch for the fuel pump. This is the way it is on my 87 Chevy van anyway. On my 85 C10, they are both beside the distributor on a brass tee. Either way works.
Mike 1985 Chevy C-10 |
Thanks for the response guys, I totally forgot I made this post after giving up in frustration last weekend.
I thought I had found the oil sender on the driver side of my block near the front, in between the exhaust manifold. Going by the book I had that was supposed to be the location. Once I started to remove that sending unit, water started seeping from around the threads. So I thought to myself 'self, this sure as hell isn't it, better put it back cause you're letting the magic out' |
LED King
That is the coolant temp sensor (but you probably figured that out). You found another sensor! Is your truck TBI or carburated?
I believe it is TBI
LED King
Then check around the oil filter like swerve said. He knows all!
