Old 04-07-2013, 12:51 PM   #1
junkman8302
junkman8302's Avatar
Rear Main issue
Has anyone ever had trouble getting the top half (block side) of a two piece rear main out? I've got my 400 ready for it and the damn thing won't budge. Any tips or tricks out there? I've already tried to push around the top of the crank from both sides and damaged the ends, with no luck. I've loosened all the main caps and pulled the flywheel bolts and pushed the torque converter back, still no luck. I just don't want to have to pull the engine if I don't have to. Thanks for any help in advance.
"I'm the only John Wayne left in this town" John Rich&Kenny Alphin
96 K1500
99 K1500 Burb (wife's grocery getter)
junkman8302 is offline   Reply With Quote
Old 04-07-2013, 01:10 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rear Main issue
Try using an old butter knife to push against one of the ends. It allows you to really bear down on it.
Tx Firefighter is offline   Reply With Quote
Old 04-07-2013, 03:07 PM   #3
LONGHAIR
Re: Rear Main issue
I have never had one stick like that. But I suppose that it is possible that someone "glued" it in there with silicone or Gasgachinch.
Is the bottom half stuck like that?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-11-2013, 11:11 PM   #4
junkman8302
Re: Rear Main issue
The old butter knife trick didn't work, I ended up pulling the engine. I'm going to put a full gasket set on it so I know there won't be any more leaks. Thanks for the advise.
96 K1500
