04-08-2013, 11:43 AM | #1 |
3/4 ton axles for my 1/2 ton...maintenance suggestions?
Just bought new (to me) 3/4 ton axles for my 1/2 ton...going from 3.42 to 4.10 gears. Any suggestions on what I should do to service them pre-transplant? I don't want, nor do I have the budget to, completely rebuild them. But I also want to do what I can to make sure they're going to be fine.
Obviously I will open differentials and change out fluid. I think I should redo wheel bearings while I'm at it. I'll go through brakes (new rotors and resurface drums, new pads). New locking hubs most likely. Posted via Mobile Device |
04-08-2013, 08:34 PM | #2 |
Re: 3/4 ton axles for my 1/2 ton...maintenance suggestions?
Sounds like you covered it all... I did the same thing and no problems yet other than i replaced the wheel bearings in the front already... Guess i didn't apply enough grease...
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
04-08-2013, 08:46 PM | #3 |
Probably a no-brainer, but check the axle U-joints while you are at it.
04-08-2013, 09:25 PM | #4 |
I would do axle/wheel seals, but that is me. I've lost rear brakes to leaky seals. Currently, my front is puking gear oil out the passenger side inner-C.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
