Old 06-20-2003, 11:36 PM   #1
Andrew68c10
Initial Valve Adjustment
I'm doing final assembly on a 350. What is the proper way to set the valves for initial break-in? I'm using an "RV" style hydraulic cam, barely larger than stock, and Vortec heads.
Andrew68c10 is offline   Reply With Quote
Old 06-21-2003, 12:00 AM   #2
Stroker
Andrew68c10 go to the cranecams link go down to the section for
Using Adjustable Rocker Arms to set Hydraulic Lifter Preload The other link has so good info if you are concerned with geometery or clearances. I usually like to use a half turn on a new engine I'd rather be a little loose than to tight. Good Luck....Stroker
http://www.hi-flow.com/HPValvetrainInstal..htm
http://www.cranecams.com/master/adjustvt.htm
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 06-21-2003, 12:27 AM   #3
bigjimzlll
bigjimzlll's Avatar
are you using self aligning rockers..or guide plates? Its easier to do the adjustments if the intake manifold is off
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
