04-13-2013, 03:50 PM | #1 |
Did these body mounts need replacing?
I started replacing the cab mounts on the truck today. I found a couple of them that may have been bad. What do you think?? I also stopped after the rear mounts because I have a couple of questions. Are the front cab mounts on an excentric bushing for adjustment? I did mark the cab position on the frame. Are the core support mount bolts carriage bolts? Mine won't come loose and the bolt turns with the nut. I can't fell a hex head on them. I'll pull the radiator to get a betther look at things. I did take it around the block with JUST the rears replaced. It already feels MUCH more solid. Thanks in advance for advice.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 04-13-2013 at 03:58 PM. |
04-13-2013, 07:31 PM | #2 |
Re: Did these body mounts need replacing?
I can't see a picture. I assume there should be one?
Posted via Mobile Device |
04-13-2013, 07:41 PM | #3 |
Thanks Chris. I'll add it again. It shows on my PC.....weird.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
04-13-2013, 07:48 PM | #4 |
I think they had 10 more miles..lol
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
