04-14-2013, 06:45 PM | #1 |
Driveshaft mistery
Bought a driveshaft off guy in town with same 84 c10 th350 (9" tail). brought it home got ready to pit it in and it like 1/2 inch too long. Whats going on here? my truck is still sitting on jack stands, so I was wondering if my rear end angle effects anything or what else could it be. Any input be helpfull.
Can I buy an shorter driveshaft yoke? Pulling my hair out lol |
04-14-2013, 07:23 PM | #2 |
Re: Driveshaft mistery
both trucks have 10 bolt rear?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-14-2013, 09:29 PM | #3 |
mine does LoL
04-14-2013, 10:02 PM | #4 |
Is pinion yoke longer on 10 bolt or 12 bolt?
04-14-2013, 10:04 PM | #5 |
Truck and auto performance nut
if you have a long slip yoke you could switch to a shorter one.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-14-2013, 10:17 PM | #6 |
mine is 5 1/2. I don't know if they many any shorter ones. All I need is 1/2 less lol
04-14-2013, 10:30 PM | #7 |
Please help!!!!!!!!!!!!!!
04-15-2013, 03:42 AM | #8 |
They used several different length yokes over the years. See if your yoke lengths are the same. Otherwise get your yoke, stick it in the trans tail shaft pull it out 3/4" and measure center of eye on the yoke to center of eye on the diff and that is the length driveshaft you need. Check eBay for used Nascar takeoffs. They are balanced to perfection!
04-15-2013, 06:23 PM | #9 |
Would it effect anything if truck is sitting on stands?
04-15-2013, 06:55 PM | #10 |
could. is the suspension extended?
04-15-2013, 07:37 PM | #11 |
wheels are off ground all 4 coners
04-15-2013, 09:48 PM | #12 |
how's it jacked up? are the rear springs "loaded", compressed with the body weight of the truck? or is the suspension dangling, fully extended and therefore "unloaded"?
04-15-2013, 10:02 PM | #13 |
rear end sitting on jack stands
04-15-2013, 10:18 PM | #14 |
then you got what you're going to get.
04-16-2013, 12:20 AM | #15 |
Can any of you tell me what shortbed driveshaft length should be with turbo350( 9 inch tail) and ten bolt rear? My yoke is almost flush with tailhousing gasket and when I measure from ujoint to ujoint i get 57".
