04-14-2013, 08:49 PM | #1 |
2,4 Drop
Is a 2,4 drop a nice and level drop? Just curious.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
04-14-2013, 09:02 PM | #2 |
Re: 2,4 Drop
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
04-14-2013, 11:57 PM | #3 | |
Re: 2,4 Drop
what size tires and wheels chief?
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
04-14-2013, 09:36 PM | #4 |
Re: 2,4 Drop
i have the same drop on mine
04-14-2013, 09:51 PM | #5 |
Re: 2,4 Drop
Sweet trucks. I'm a on a budget so I'm just goin to put in drop coils. Hoping that they will bring it down and level.
04-15-2013, 01:03 AM | #6 |
70+ ( Old Skool Club )
Re: 2,4 Drop
What size rubber you have on there?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-15-2013, 08:00 AM | #7 |
Re: 2,4 Drop
04-15-2013, 06:58 PM | #8 |
Re: 2,4 Drop
Wheels are 18x8. Tires are 255/55x18.
04-15-2013, 07:08 PM | #9 |
Re: 2,4 Drop
Tires are 275/75/15 2 /4 drop on the cheapo cut 1 coil on front and Jeep springs on the back.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 04-15-2013 at 07:09 PM. Reason: brain fart |
04-15-2013, 09:45 PM | #10 |
Re: 2,4 Drop
I was on the same path as you as far as saving money with a 2/4 drop. But after I did it I just had to take it lower. When I called ECE to try to return the springs, he laughed and said, guys do that ALL the time.
My advice is to go to a car show and take a good look at other trucks with different drops before making up your mind. Doing it once saves some time and money. Good luck! |
04-15-2013, 09:45 PM | #11 |
Re: 2,4 Drop
04-15-2013, 10:33 PM | #12 |
I am a Referee of life.
Re: 2,4 Drop
Keep in mind that 2 in drop springs will probably not net you 2 in of drop.The original springs usually have some sag to them and it "may" already have a bit of droop to it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-16-2013, 09:16 AM | #13 |
Re: 2,4 Drop
My suspension is pretty much shot. All of my shocks, and front and rear sway bars are gone. It's time fir new components.
04-16-2013, 09:26 AM | #14 |
Re: 2,4 Drop
Just to note, .. and you kinda said it too If your springs are original, BUT they are 40+ yrs old. They will have sagged a bit. When you put in new drop coils even though they are 2" drop you won't really get a full 2" drop compared to where it is right now. That measurement is taken against new original springs and doesn't take into consideration, age, use, and just general sag over time. Notice one mention of 2.5" drop spindles. I would suggest spindles up front (you will get the full drop this way) and even replace your worn factory springs and you retain the original steering geometry, ride quality, no alignment needed, original shocks can be used, etc. IF you put drop coils up front you change all that. Ride, geometry, alignment and shock length. Drop coils = $115. Drop spindles = $250 .. most definitely I would wait, save a little more $$ and do spindles up front. Coils in the back are easy. Chevelle, or 97-06 JEep TJ rear coil springs will also lower it but they are a bit softer. Your truck will be kinda squishy feeling in the back and you wont be able to haul a whole lot. .. just my .02
04-16-2013, 09:59 AM | #15 |
Re: 2,4 Drop
Well I thought that you have to convert to disc if you get drop spindles? I'm just trying to get my truck on the road but I need to replace a bunch of stuff and figured might as well drop it a bit in doing so.
