Old 04-15-2013, 10:30 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
I got a 400! Just a couple opinionated questions, though
Currently it has a stock aluminum spreadbore Quadrajunk intake on it, with a spot for an EGR. Should I just go with a TBI intake [which would be a Holley Performer with a spacer I already have], or an adapter possibly with a spacer I already have to mate the TBI to the current intake?
Also since I'm going from a 350, has anyone ever used a balancing plate to make a n internally balanced fly work on an externally balanced engine? I'm already getting a new harmonic balancer because it has none currently.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 04-16-2013, 07:06 PM   #2
blazerkid
blazerkid's Avatar
Re: I got a 400! Just a couple opinionated questions, though
no you need a 400 externally balanced flywheel and harmonic balancer
the 454 tbi's had a Quadrajet intake with a adapter so you can git one to use a Quadrajet intake on it
or modify your tbi intake to use it
blazerkid is offline   Reply With Quote
Old 04-17-2013, 07:00 PM   #3
gmclowsierra
Wwe bought an adapter weight and used a 350 flywheel on the last 400 I put together.
gmclowsierra is offline   Reply With Quote
Old 04-20-2013, 09:40 PM   #4
Rogue_Alphonse
I've read about those adapters and haven't found any bad comments about em, but it never hurts to get more opinions!
