04-16-2013, 03:11 PM | #1 |
stage 1 front bags
Does anyone have any pics of the porterbuilt stage 1 front bag kit with shock relocater installed on a 73-86 truck that they could share with me? I would greatly appreciate it.
Posted via Mobile Device |
04-16-2013, 05:35 PM | #2 |
67-72 parts collector,…
Re: stage 1 front bags
Are you wanting a view of the entire truck or just the suspension?
04-16-2013, 06:35 PM | #3 |
I'm wanting a pic of the suspension, I'm installing the bags on my truck and trying to see if I'm headed in the right direction. Do the factory bumpstops come off, if so upper and lower? Also what about the bracket the bumpstop is mounted on?
04-16-2013, 06:40 PM | #4 |
This is a good bag install thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=575686
04-16-2013, 07:06 PM | #5 |
You can leave the upper stop on the truck, but it is best to trim off the lower stop. This will make a little more room for the bag and clean things up. I do suggest so some of bumpstop as a fail safe if for some reason you lose air pressure. This will keep the front crossmember from digging into the ground if it happens while driving. Depending on wheel size it may not touch the ground, so one may not be needed. I would set it all up and go from there.
04-17-2013, 08:19 PM | #6 |
that's what I needed to know, thanks
