04-17-2013, 09:14 PM | #1 |
Repeat
I'm looking for thread on installing relays on headlights that has a complete parts list
Posted via Mobile Device |
04-24-2013, 09:28 PM | #2 | |
Re: Repeat
Headlight Relay System Contributed by Jolly Goodfellow Craig Ueltzen Scott Temple For this 7 Year run of GMC Trucks, they have quad headlights. Upgrading to Halogens will overload the old wiring found in these trucks. The pathetic wiring in most old cars is not really good enough for the power draw of newer light bulbs. The old switches will start to fail too. This method replaces the bulb's power with heavy wiring & relays in the engine compartment. The original wiring under the dash remains untouched. You will be needing two of these Bosch Relays for this Conversion. Any Good parts house can get them for you. My self I plan on using the Heavy Duty 75 amp version. The smaller 15-20 amp relay will work good in most cases, and are easier to find. Turn on the lights & use a test light to find out which color wire goes to which bulb terminal. You will need to know which is high beam & which is low beam. The dash indicator determines this later. Write them down somewhere for future reference. Keep track of which wire goes to what bulb terminal also. Cut the wires going to the headlight bulbs & reroute them to each Bosch Relay's terminal #85. Ground each relay's terminal #86. This makes the headlight & dimmer switches control the relay with a very low current draw. The old headlight & dimmer switches will keep going as long as the mechanical action lasts, because arcing & heating of the switch contacts disappear with this project. Turn on the lights & operate the dimmer switch. You should hear clicking noises from the relays. Watch the dash indicator & leave the lights on high beam. Use a test light to see which relay is on. Mark this relay "High beam." (You should already know which relay is high beam if you wrote the wire colors down first). Use 12 gauge wire for the "High Beam" circuit & 14 gauge wire for "Low Beam". Use non-insulated terminals & heat shink tubing on all connections. Connect a 12 gauge wire to terminal #30 of each Bosch Relay. Route the 12 gauge wire to a point with battery power, you should use some kind of junction block & it should be powered by a 10 gauge wire from the battery "positive post". You may have to purchase a battery terminal to enable the 10 gauge wire to attach to the battery itself. You also might want to put a 40 amp curcit breaker close to the battery inline of the 10 gauge wire. An alternate method is to tap onto the big wire(pos batt cable) going to the starter terminal. Don't power up the 10 gauge wire before you get the relay end done, unless you like fireballs in your face should it touch the frame! Run the 12/14-gauge wire for each circuit from each relay's terminal #87 to the head lamp Connectors. The best way is to remove the old wires from the bulb sockets by pushing in the tab "ear" from the side to get the connector out. On some sockets, you will need a skinny tool pushed down along the terminal from the front of the socket to push down the tab. Solder the high/low wires to the connectors. Replace the ground wires with 12 gauge while you're at it. This avoids the crappy looking 1" splice at the bulb socket. Be sure of which terminal is what before you tear them apart. You can solder the wires together at the bulb, & run the set to the other light bulb. You will have to split the wiring somewhere to feed the two sides. Scope out the vehicle for the best way to route them. I can send you a pic of the diagram if you PM me your email addy. Sam |
