Post your set up
After reading some posts here Im amazed how fast the trucks some of you members got so please share with us your set up and stories,I got a 383ci internal balance 6" rods roller engine and AFR 1054 heads and trick flow camshaft 246/254 @ .050 .555"/.555" on 1.5 rockers( I will be using 1.6) 112lsa,victor jr intake manifold and Holley street HP 750 full MSD ignition hooker 1 3/4 long tube headers TH350 that has been rebuilt and tricked B&M holeshot 3600 stall 8.5" rear end but for now it has 3.08 but will change it to 3.73 and go with 15x12 rear wheels the engine and alot of stuff are not in the truck yet Im working on the wiring now and after I get the truck inspected I will drop everything in and see how it goes
Re: Post your set up
Nice looking truck!
Registered Truck Offender
Welllllll How far back would you like to go
The ol 66 has been through a lot. Was a retired farm truck in need of ...... well everything! Started with a Alston urethane bushed 4link backhalf, 350 with Edel RPM heads and 33x22.50-15 MT (hard as nails) Sportsmans 13.6ish @ like 85mph,, and 11.7something @ 114 on a 200 horse shot (blacktracking to the 660' cone) Couple of iterations of street motors then ..... Next came a mild 383 with box stock AFR 210 heads, Crane hydraulic roller(236°/ 248° @ 0.050 .575 lift. RPM intake, 5.43 gear / locker in a 9", 33x22.50-15 Hooser QT Pro , TH350 I built and a 3500 stall converter 11.9 in good air, 12.3 @ 112 in normal Az heat. Then street ceased to be anything more than a novelty. After some bad luck with blocks, carbs falling apart and going down the intake, plugged oil pickup, and generally stupidity... The backup motor for my Nova (the 666hp possessed POS!) and stuffed and Hughes TH400 at it, Midwest 4800 stall 10" converter, changed to a 4.30 gear, 33x14 Hoosier DOT slick,, (Dart LittleM 4.165" bore,, reworked Eagle 4" crank, 6" Oliver rods, JE 8cc domes, Crower 268° / 276° @ 0.050, .625 lift, AFR 220 heads, Crower 1.55 Shaft rockers, Holley ProRam, a pair of Proform 750 carbs), Custom 1-7/8 LOnnnng tube headers, Through mufflers at the closing of Firebird event it with everything staying together finally.....it went 10.92 @ 119.4 right off the trailer, Then Round 1 of eliminations it went 10.80 @ 120.3 Then 2nd round it went 10.73 @ 121 and lost ,,, I think the pig has stayed together long enough this time the rings are finally starting to seat!!! Still drive it around on the street some, but fuel cost has gone up considerably since it was a mid 12 second truck. Street miles are rather limited now. Hope to get back for the ADRA race in Tucson next month to see if the 666 saga continues. Tucson has always been good luck for me ![]()
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 04-22-2013 at 08:31 PM. |
Well I hope I can hit 11s I will get caltracs also for traction cant go with four links or ladder bar in my country its not allowed in traffic department I will try my best N/A after that spray all the way
mini truck racer
Mine 385 inch SBC 6" rod , eagle forged lightweight crank , SRP pro series pistons with Hellfires . GM fastburns , XE288HR , rpm airgap , Demon 750 , MSD 6530 6AL-2 box , TH400 with Freakshow 4200 converter , 9 inch 4.11 splitmonos and caltracs soon going glide .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
