![]() Join Date: May 2011
Parking brake help please;)
Have you ever lost something in your garage/shop? I lost/misplaced some parking brake parts and I can't find them anywhere!
![]() Maybe I won't need the parts I've misplaced, but here's what I've got; The brake pedal assembly came out of a 73 Impala. ![]() So the cable comes down and goes through the floor and a little bracket I'll make to hold it. However, this cable is broken too. ![]() Here I will make a hole for the parking brake cable to go through the floor support and follow the outside of the frame: ![]() Then using this pulley from the Impala will make a turn going towards the middle of the truck towards the brackets I lost! Then I need another pulley like this; maybe I can get something at ACE to make work. ![]() The two cables that come off of the backing plate aren't any good; they're very rusty and not useable. They appeared to be factory, even had a grease fitting(someone forgot to grease it!). And can someone please identify this rear axle? ![]() ![]() questions: I found the factory cables that come off of the backing plate on Ebay for 130. but are there other cables that come off of a backing plate that will work? I can purchase the entire parking brake system for a 73 Impala off of ebay for 130.00, but I don't know how much of it I could actually use. http://www.ebay.com/itm/71-76-Chevy-...634c01&vxp=mtr This has me stumped, I don't know how to proceed on this; it appears to be easy. Any advice would be much appreciated! ![]()
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
![]() ![]() Join Date: Nov 2008
Re: Parking brake help please;)
Somewhere here someone posted that replacement pulleys can be found at Home Depot/Lowes made for garage doors. I think if I were you I'd pull the rear cables and head to Autozone, O'Reilly's, etc and pick out duplicate replacements.
Posted via Mobile Device |
i removed mine and let it sit in Aero-Kroil for 2 days. It loosened up all the rust and made it roll like new again. That was for the pulley. Sorry I can't be of any help on the cables. I'm running a chevelle rear end and a relocated factory E-brake handle
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
I am running a 12 bolt rear end from a chevelle I used the rear brake cables from a TF repo's they worked. Bought them off ebay, brothers sells them
http://www.brotherstrucks.com/prodin...number=CR91949
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
The Impala setup looks similar to the 74 truck I used. Note that the end circled below is designer to fit is a sturdy fixed hole and secured with a u-shaped clip. This holds the outside while the interior cable moves. Your truck should have had the same puller and bracket unless it was removed by the PO. They are available as reproductions, but any pulley and bracket will work, you could just use a piece of tube over a bolt, all you need is something that will rotate at the cable change in direction.
Y'all are the greatest~ I like Dan's(and of course all of the ideas were superb) idea of going to Oreilly's but those guys do not like to see me walk in the door! They cannot function without a reference! Rude dude, I looked at the parts at Brothers, the link you gave me, but I don't think those would work. My rear axle is not the original axle.
I got the cable to slide, but the springs are shot, and the metal spider finger looking retainer is totally gone on one and the other~ I fear is shot too. I maybe could go by application at the parts store if I knew what this rear axle came off of (I know it's a 12 bolt ![]() ![]() Orrie, I do plan to fabricate a bracket, I think that may be easier than sourcing the parts I need. Nothing like retro fitting! ![]() ![]()
I feel your pain. I quit going to Autozone for that very reason. Advance Auto in my neighborhood is the last place who hires old mechanics or in my case an x-GM PR guy. That guy has an answer for everything.
http://www.rockauto.com/catalog/more...799&cc=1030329
#9 | ||
Thank you Orrie! I just went out and checked the measurements on mine; the entire length is 61 1/2"; the conduit is 32". I believe that maybe when whomsoever installed this rear axle, they used the existing original/or not original rear brake cables? The truck did have the entire old hand pull system, but everything was seized and it was all coming out anyway.
Andy, how about this, I ask for a part, lets say a water pump, what's the make and year? They ask. I tell them, but they know the truck does not have the factory engine, but they ask anyway! I told them I needed a lower radiator hose, he ran up and had the factory lower hose for a 213, and wasn't near close to fit my 350sbc! I just look at them cross eyed ![]() Thanks Daze, I'll check that tomorrow!! Quote:
Like I said the rear cables are repo TF and worked on the chevelle rear end brakes.
denee007
on the passenger side axle tube there should be some numbers and letters that -when you look up rear axle codes -should tell you what you have - ya might have to use some cleaner or sandpaper towards the top of the tube - code should should be there Last edited by Daze57; 04-23-2013 at 07:32 PM. Reason: wrong side |
sorry i did mean passenger side !
Hollister Road Co.
its a car 12 bolt rear
Hollister Road Co.
#15 |
Hm, thank you Orrie for that link! The part below is what's on my truck, but it doesn't work with my backing plate. I'll keep looking on there
![]() http://www.rockauto.com/catalog/more...020&cc=1489132 Posted via Mobile Device
#16 |
Denee,
This thread may help you. At least the input by Russell at the end. If you follow his method it'll keep you from having to deal with the dufus (dufi?) at your local auto parts store. How it helps. http://67-72chevytrucks.com/vboard/s...=parking+brake |
#17 | |
Thank you Dan! I checked out that link~ Russell did an excellent job using his old brake handle! I like that idea, but I think I would still like to go with my floor pedal. Besides, I think my fuse panel that I put in is in the way of the original brake handle, but I'll check. I sent the (www.controlcables.com) some pictures and the links from our truck site. Getting a little excited here!
![]() ![]() Dan, Thank you ![]() dne' Quote:
#18 |
Napa has great reference books, gives lengths and has pictures, I just put on a set that looks exactly like yours, started looking at 72 nova. And I think ended up with 76 nova, to get the length I wanted, I'm actually pulling these new ones off , decided to do a disc conversion, if you're not in a hurry, you can have these. Or, they were only like $10. At napa
#19 | |
Hi Skip! hmm, that's very nice of you
![]() ![]() ![]() ![]() Quote:
#20 |
I would have never thought I would have room for the stock hand pull brake lever! I would have bet money that it would not fit! but it clears just by a tiddle! I may just go ahead and mimic what Russell did. The reason being, the way I have it, the brake cable is on the outside of the frame, whereas this would be on the inside of the frame making it easier to run the cables.
neato~! ![]() ![]()
#21 |
And don't forget...you can buy a CHROME stock hand brake handle! Lol.
#22 |
You should hear me laughing here!
#23 |
But I will look into that!~ that would look nice!
#24 |
Maybe this will help. I ran the foot cable conduit thru and existing hole in the frame, then thru the original cable holes in the crossmember (in the photo I had not looped it thru the crossmember yet). I made up an adjustable bracket with the original clevis pin. I shortened the original cable to the rear, a looped in and secured with swage fitting. I had to relocate the pulley to the rear so the cable missed my MC. Everything else is stock 59 at the pivot brackets. To use the 74 rear end cables I had to move the conduit end angle brackets but the length fit the 59 pivot assembly on the frame fine.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 04-24-2013 at 01:28 PM. |
#25 |
Here is the back end, stock brackets, relocated cable bracket and pivot rod spring.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 04-24-2013 at 01:27 PM. |
