Bed Wood
I'm restoring my '57 3200 but intend to haul stuff in the back.
I've ordered my unpolished stainless strips and angles from Mar-K. Has anyone ever just bought a 4'X8'X 3/4" sheet of high-grade or marine-grade plywood and put the strips directly on top? Seems like it would be cheap, effective and look like individual pieces. I've got a router so I could put in grooves but I'm not even sure that would be necessary. |
Re: Bed Wood
Thing is the bed is 50 1/2 inches inside. I used the plywood and dowled and glued two 1x1 strips on each side. Due to the way wood is measured, it added the 1 1/2 inches perfectly and you can't see it when installed because the angle strip covers it up when you bolt it down. The other thing is you can't put a whole peice in because of the way they made the bed angle strips. I had to cut mine in three pieces to install and covered the cuts with the bed strips. It worked out really well for me but it's not quite as easy as it seems.
Old Heap Driver
Re: Bed Wood
I used oak plywood, no complaints at all. Mine were cut into 12" wide boards, saved me money on strips. LOL If you buy the plywood at Lowes or Home Depot they will cut it for you for a small fee.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#4 | |
Re: Bed Wood
Btw, nice thing about living in a small town, HD will cut my lumber with no fee. They're supposed to do just one cut free and charge for more but most times they don't. Only one cut is needed on this anyway. |
Re: Bed Wood
what im planning on doing is laying a sheet of plywood or something then laying something like lumber liquidators has so i can have any style of finish on top. i found some really neat bambo tiger stripe stuff that im gonna get when i build my bed
Old Heap Driver
Re: Bed Wood
I didn't add any grooves to the plywood, the strips lay on flat wood. It's been 4 years and everything is still as tight as it was when installed. I do need to replace my plywood though, not enough sealer/varnish on the edges, the wood is beginning to come apart. I take my cover off during the winter to protect the vinyl leaving the wood exposed. Custom cover $350.00, Plywood $40.00, no brainer. LOL
#7 | |
Re: Bed Wood
by the time you buy/find a 5'x9' sheet of marine grade plywood it would be cheaper to install a stock pine floor in your truck stock bed wood was yellow pine painted black and it typically lasted 20 yrs or more before needing new wood i don't see plywood lasting that long or looking good at all you can use a router to grove the boards but it is a lot easier to use a table saw 2 cuts is all that is required for each edge ![]() an option though not cheap is trex decking from hd this is trex in my truk ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#8 | |
Re: Bed Wood
After measuring, I was already thinking along these lines. Did you just put all the strips directly on top or did you use a router to cut lengthwise slots? |
Re: Bed Wood
There is a thread here somewhere that shows what you are talking about.
Someone used a router to section out some grooves in a one piece floor and the strips sat down level in them. Looked really good and got me thinking I might do the same but for the life of me I can't find that thread for you. I'll keep looking because not finding it is going to annoy me now! Posted via Mobile Device |
Re: Bed Wood
dang it! called out by orrieg
again ![]()
Re: Bed Wood
I went to a local sawmill and bought 8 ft long 8 inch wide by 1 inch tall boards that are cypress it is used a lot in boat making and doesn't rot almost like cedar ... I got all my boards for 52 bucks and had two extra just a thought if you have a local sawmill.....juniper wood is also rot proof they say
#12 | |
Elev8r Man
Re: Bed Wood
Which means I saved about 339.00 so far on the bed wood. Not sure if I should go with the polished stainless steel strips, or get the plain strips and have them powder coated to match my beige 2 tone. Took to a buddy who does cabinets and he is going to cut down to size and cut the small side grooves into them. Then it's up to me to finish them. I am excited as this means I am that much closer to getting this Pick up back on the road.
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
Re: Bed Wood
Thanks for the tip!
Re: Bed Wood
I pulled these pine boards out of the attic of a house built around 1900-1910. One of them is 16" wide, I might use them for the bed of my truck. The people that own the house are getting ready to demo it, there is also an old carriage house with the same width boards coming down.
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
#15 |
Re: Bed Wood
I had a retired custom cabinet builder custom build mine . He had a pole barn filled with kiln dried lumber, walnut, oak , pine, birch etc. He only charged $125 and you had to spend some time chatting with him about the old days! Education on wood working and a savings in one !!
