Old 04-26-2013, 06:42 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Shock Absorber Question
I am going be swapping the rear end in my truck and am wondering if I should change the shocks at the same time. I've had the truck ( 72 Chev longbox )since 2001 and the only thing wrong with the shocks that are on it now are the squished rubber bushings. The shocks dont leak and the truck sits as it should. Is it practical to put the same shocks back on the truck?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-26-2013, 11:59 AM   #2
69gmcc10
69gmcc10's Avatar
Re: Shock Absorber Question
I have seen shock companies state that shocks need to be change every 50K miles, but I would check them first. If you push the vehicle down on one of its corners and let go the suspension should travel up and and down far enough stop at ride height. If the corner you push rebounds up and back down past ride height without a positive stop it is time for new shocks.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 04-26-2013, 04:41 PM   #3
Already Gone
Thank you for the tip. The shocks work as they should and there are no leaks. I wouldn't mind putting new ones on but I'd rather spend the money on new carpet as opposed to a new set of shocks so if the ones on the truck will work I woud just as soon retain them.
Old 04-26-2013, 06:01 PM   #4
69gmcc10
69gmcc10's Avatar
If you really want to you could buy polly replacement bushings for a few dollars, but as long as the mounts are in the same locations there is no need to get new ones.
