Old 04-29-2013, 01:08 AM   #1
tinydb84
tinydb84's Avatar
motor mount tower question
I pulled the big block from my 75 yesterday. I heard I need small block towers for my swap. Is this correct and where would I find them?
David
Instagram: myfabguy
Old 05-01-2013, 09:59 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: motor mount tower question
I am usually in the 67-72 side, but I don't think that the frame towers need a swap on your 75. As I see them, the have multiple holes, to accommodate the fit. I am not sure about the engine brackets tho. You might try to post it in the 73-up forum, or PM Captian Fab for more specific info. He has played with the 'square body" trucks, & can most likely tell what is same, or different best of fun,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-02-2013, 12:48 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
again, I'm on a different body, but I used my I6 perches (towers) to put mine in, with the "usual" sbc to lsx adapter plates. If the towers you have now can accept the bolt pattern of a regular sbc motor mount, then you'd be able to use the adapter plates as normal.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-03-2013, 06:19 PM   #4
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Mine is on big block mounts. I think they are the same. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-03-2013, 07:09 PM   #5
crazy longhorn
67- 72 were very specific on the stands, for the engine....3 sets of stands(well 4 ,if you count the 72 BB ). At any rate, the 67-72 spaced the sb 3 1/2" farther ahead, vs the sb bolted on I6 /250 spot. The BB came in the middle of these 2 figures, & was mounted a tad higher in the chassis on its own mounts/stands. The 73-up....I cant 'tell it" all on, but my bet is any diff on the height of the engine, will be due to the brackets that bolt to the block? Now this is just speculation, on my part.....if I am off on it, I invite all swappers in to correct the problem? I don't profess to know it all....if I missed it, lay it square I have been collecting parts , this last yr & will be doing that LS swap in my longhorn....its new to me, so any info that I pick up, will also help me! Best of fun,crazyL
Old 05-04-2013, 04:21 PM   #6
Robznob11
Robznob11's Avatar
In my 68 frame i used towers from a 73 and up dont know if they were bb or sb specific but they make a straigt line from top of the frame rail to c member i used a piece of plate and welded the oe clamshell to it. Used the oe bottom hole on shell to line up on bottom front ls oe hole and drilled the front top hole through the center of the shell. I used the stock 73 up rubber mounts that the shells fit over. These towere allow you about 2-3 inches front and back movement of engine if you drill new holes in frame and c member and with a stock truck pan it puts about 1" of space between c member and pan. Down side is bottom of pan hanges about 1" below c member and also you would have to clearance frame to fit ac compressor in oe spot. But you may have that issue anyhow!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-04-2013, 10:39 PM   #7
crazy longhorn
Many ways to "skin the same old cat" He11, I wont know exatly where I am going, till that 5.3 is across the rails! I have seen the job done many ways....no right /wrong, all she needs to do is fit crazyL
