Old 04-29-2013, 06:20 PM   #1
Mr_B
What differential do I have
Hello all,
I have a mistery on my hands that no one seems to be able to solve.
So, I thought I'd try here. I appreciate any info.
The Truck: 1963 GMC C1000
Differential cover: 10 Bolt (3 inches from bottom bolt to next bolt in line)
Gear Ratio: 3.90:1
Ring gear dia: around 9" (little rough measuring with a tape measure)
Mr_B is offline   Reply With Quote
Old 04-29-2013, 06:54 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: What differential do I have
Top right hand side of axle housing will have series of letters / numbers, that will tell us what it is......
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-29-2013, 08:35 PM   #3
64tantruck
64tantruck's Avatar
Rear diff cover looks like a Dana 35 rear end. Thats what our 61 has in it.
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 04-29-2013, 08:54 PM   #4
j.kirn
eaton h032
j.kirn is offline   Reply With Quote
Old 04-29-2013, 08:56 PM   #5
64tantruck
64tantruck's Avatar
Ok, does anyone know if the square plug
Can be removed to fill/check the rear did
Gear oil?
Glenn Korec
Jamesville NY
Old 04-30-2013, 01:03 AM   #6
Captainfab
60-66 Nut
Yes that rear plug is where you fill the differential with gear oil. The bottom of the fill hole is the proper level. And I agree with j.kirn, that is an Eaton HO32 differential.
Old 04-30-2013, 08:12 AM   #7
64tantruck
64tantruck's Avatar
Thanks Capt Fab. Looking his pics I see some differences. Ours has studs with nuts to hold the cover on. His has botls. Thanks for the info on the plug to fill the level. I have tried removing our plug with no luck. Its most likely been on since 61.
Glenn
Glenn Korec
Jamesville NY
Old 05-02-2013, 06:41 PM   #8
Mr_B
Thanks a bunch. I now have a good idea where my options are.
