Ground strap location
Can anyone tell me where this ground strap belongs? One end is screwed into the firewall but the other end is loose. This is a 66 C20 with a 327. Thanks!
Re: Ground strap location
Should be bolted to the back of the cyl. head
![]() Join Date: May 2009
Check the diameter of the hole in the ground strap that will give a clue. Are you looking for the factory location for resto purposes? And I don't know for sure, you might check in the factory assembly manual. I'd just match it up to the closest bolt that fits in the hole in the strap. Someone changed motors and forgot to hook it up I'm guessing, good luck...Vernski
#4 | |
x2
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
Back lower valve cover bolt is the correct location
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
I was thinking it goes to the engine as well. But where? Does it just go to a valve cover bolt?
This is an original truck, btw. |
Valve cover is acceptable, some chevy models, used the valve cover bolt for the ground, my original is on the inner front fender right side to frame...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
