05-02-2013, 09:39 AM | #1 |
Driveshafts
I'm in the process of mocking up things on my '53 3100, I have the Camaro rearend and SBC motor/350TH tranny mounted, next is the driveshaft. I know that whatever I choose probably will have to be altered, but this thing is going to be LONG. I've looked at the local pick-n-pull, nothing seems to be long enough. Any suggestions, besides a custom made one?
05-02-2013, 10:55 AM | #2 |
Re: Driveshafts
I used a 2pc S10 4x4 shaft on mine. If you get a 2wd 2pc, you can mix and match front/rear shafts and it'll give you 3-4 inches of length difference. I'm running an S10 4x4 rear diff, with a SBC/TH350 combo as well.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
05-02-2013, 11:11 AM | #3 |
Re: Driveshafts
a 3100 one piece drive shaft is not that long
a 3200 or longer i'd look at 2 piece i'd go one piece for less complication quit looking at the fwd drive shafts
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-02-2013, 11:11 AM | #4 |
Re: Driveshafts
I put a 350 with a short tailshaft th350 in mine I got the distributor as close to the firewall as could.
I'm using a 95 caprice drive shaft that's around 56" long (center to center on u-joints) It's a perfect fit with about 1 1/2" at the yoke. Can you put a yoke in the trans and pull it out about 1 1/2" then measure from the center of the u-joint to the center of the u-joint on the rearend? |
05-19-2013, 07:46 AM | #5 |
Re: Driveshafts
escalade 00 06 54 1/4 cntr to cntr 1310 to gm 3r conversion u joint for my 74 Camaro ten bolt and 1330 to gm 3r joint for th350 with a 7 inch yoke. measured yoke from cntr of u joint to end
