05-03-2013, 09:39 PM | #1 |
Big Block only parts.
Been looking around for a list that has the differences between the small block and big block parts. I'm going to be running a big block in mine since it's originally a 396 truck, and the frame is a big block frame. So, I know the engine stands are specific. What else is big block only? Here's my list:
- Throttle linkage (will probably change to 71/72 style) - fan shroud - shifter linkage Anything else that's not part of the engine that I missed? I wouldn't think much else, it's all engine / trans from there. |
06-17-2013, 11:48 AM | #2 |
Re: Big Block only parts.
What makes the shift linkage big block only? Because of the engine position?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-17-2013, 12:44 PM | #3 |
06-17-2013, 01:02 PM | #4 |
Cab floor, heat shields, dual exhaust brackets, manual crossmember, drive shaft and differential depending on specific application.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-17-2013, 02:06 PM | #5 |
SS Tim, is the driveshaft only unique because of the length? Also, what is different about the differential, say for a C10?
06-17-2013, 03:18 PM | #6 |
There are a myriad of drive shaft service part applications. The best way to check is to determine exactly what you want to end up with and see if what you have crosses over. Again the parts manual is for service repacements but most carry Big Block and 4-speed application exclusions.
06-17-2013, 07:56 PM | #7 |
I am a Referee of life.
All of the accessory brackets are specific.PS pump,alt,A/C, and expensive to boot.IIRC the clutch z-bar if you run a standard.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-18-2013, 10:56 AM | #8 | |
Do you mean the engine mounts or is the frame different on a big block? Sounds like my big block might be worth a bit just in parts!
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
06-18-2013, 12:24 PM | #9 |
Big block frames are clearanced in the engine compartment to clear the larger engine.
06-18-2013, 03:01 PM | #10 |
Watch out for your cornhole !
Show me a difference in the frame itself where it's factory clearanced between big and small block trucks. Or even an inline 6 for that matter.
Posted via Mobile Device |
06-18-2013, 03:11 PM | #11 |
Look at my build thread, post 41. You can see it, on the inside of the frame, it is cut back behind the front crossmember. There's a thread in the build section of someone cutting their frame to match this.
06-18-2013, 03:40 PM | #12 |
I was thinking of swapping out a 307 for a 402. I thought all I would need was different mounts. guess that's not the case huh. 72 c20
01-24-2014, 02:14 PM | #13 |
400sb would be a direct bolt in and gain you almost 100 cubes. Reuse all your parts except the balancer and flywheel. Heck tell everyone it is still a little 307 if ya like.
06-18-2013, 04:51 PM | #14 |
I have built three big block trucks of my own. None of them were big block originally. On all three of them, I used factory big block mounts to do the install. Absolutely no cutting or trimming is necessary at all. They fit properly and clear everything. I did look at your thread in the referenced post and can't figure out where you're referring to that you modified.
06-18-2013, 04:56 PM | #15 |
I went back 9 years and found an old thread I posted a bunch of pictures in. That was a 1970 model, original 6 cylinder 3 speed column shift truck. I converted it to 454 and turbo 400 with all OEM parts. The only deviation I made from exact OEM was using small block engine rubbers in place of the more expensive big block ones. But, the frame stands were original 68-71 396/402 big block stands. It all bolts right in with no mods at all.
http://67-72chevytrucks.com/vboard/s...d.php?t=110775 |
06-18-2013, 05:20 PM | #16 |
http://image.truckinweb.com/f/images..._ton_frame.jpg
That's a regular frame, see behind the crossmember the frame is straight on the insides. Then look at my frame and you'll see the difference. The bog block trucks had them cleared for more room. I'm sure a big block will fit without anything hitting on a regular frame, but they did have a seperate frame for big blocks. You can see the difference pretty well in this pic. |
06-18-2013, 05:29 PM | #17 |
Never seen a frame difference in all the trucks I have owned both large and small block. Even converted a few back and forth
06-18-2013, 06:03 PM | #18 |
Had me worried for a minute there. Thanks for clearing that up Tx firefighter. Not trying to get too far off topic but what type of hp/ tq can I expect out of a fresh 402 4bolt built with somewhat performance in mind and pump gas?
06-18-2013, 06:19 PM | #19 |
IIRC there was a running change on the frame flanges when the Big Block was released in late 67 clearancing the frame for the exhaust manifolds. This change was incorporated in all frames subsequent.
06-18-2013, 06:26 PM | #20 | |
If I remember correctly, the top flange of a '67 frame measures 2.5" wide while a 68 frame top flange is 1.8" wide. I got these measurements from my '67 frame and my friends '72 frame. They ALL got narrowed once the BBC was an option in '68 to allow room for the exhaust on BBC, when equipped.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
06-18-2013, 07:32 PM | #21 |
I wouldn't be the guy to offer an opinion on the power figures. Pretty much all the junk I build gets stock engines with aluminum intakes, cast iron exhaust manifolds and modest carburetors. I'm kind of a one trick pony nowadays. I wasted too much money chasing horsepower in my air cooled VW and 5.0L Ford days. Now I just like reliable and trouble free stock-ish stuff.
06-18-2013, 10:03 PM | #22 |
Thanks still.
01-24-2014, 01:38 PM | #23 |
So, what else is big block only? We know the motor mounts/frame stands, shroud, shift linkage, throttle linkage/cable, cab heat shield, exhaust brackets, drive shaft, high hump floor so far...
01-24-2014, 02:19 PM | #24 |
The u-bolts that hold the lower control arms to the frame are larger on big blocks
01-24-2014, 03:49 PM | #25 |
Roadtrip!
High hump floor is not only big block. I had a big block 3 speed truck with a low hump.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
