Old 05-08-2013, 03:51 PM   #1
SigFTW
Control Arm Bushing replacement
I'm about to replace all the front control arm bushings on my 1979 C10 and drop in a new set of lowered springs.
Anything special tool I need other than ball joint separator tool?
SigFTW is offline   Reply With Quote
Old 05-08-2013, 04:08 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Control Arm Bushing replacement
They just suck to change. I've been doing this stuff over 20 years and still avoid doing 73-87 bushings if I can. I use a very powerful air hammer to drive them out and a shop press to install the new ones. It's still a pain. It's easy to crush the lower control arms where the bushings pass through both webs if you aren't careful. I've asked other guys who are pros and they don't have any easier solutions to offer.
I actually have a set in my shop to put in my 78 real soon. This time around I chose Prothane brand since they resue the outer shells of the originals. I'm hoping it will be a much easier swap because of this.
Energy Suspension and stock replacements require replacing the outer shells. These are Energy Suspension ones I did a few years ago.
Tx Firefighter is offline   Reply With Quote
Old 05-08-2013, 04:19 PM   #3
SigFTW
I have the Energy Suspension ones to install.
Old 05-08-2013, 04:43 PM   #4
cory d
cory d's Avatar
some people burn the rubber out, some drill it out. i just opened up the inter rolled tube with a hammer and chizzle and used a punch to beat the outer sleeve out. soaking in penetrating oil helped once i got them moving. it took me about 4 house to do all of them and i was busting ass. but that was my first time
cory d is offline   Reply With Quote
Old 05-08-2013, 05:22 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
I gave mine to car quest they threw them in a furnace then a rotisserie bead blaster. That made it much easier but it cost me $160. I drilled and tapped for zerks after that as well
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-08-2013, 06:44 PM   #6
cory d
cory d's Avatar
............cheater
Old 05-08-2013, 07:24 PM   #7
naphtali5725
naphtali5725's Avatar
Big hammer, cold chisel, and an air chisel.... easiest I have found. The C clamp ball joint tool, and bushing tool from H/F comes in handy unless you have a press... good luck
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-09-2013, 05:58 AM   #8
S10Fan
Old Heap Driver
I burn out the rubber, cut a slit in the outer steel then air hammer the sleeve to submission.
As stated above sucks either way you do it.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-09-2013, 09:20 AM   #9
Koffer
I cheated and got new loaded upper control arms since my upper ball joints were shot,bushings were beyond shot and bumper was missing too. $51 a side from rockauto it was a no brainer
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model )
Koffer is offline   Reply With Quote
Old 05-09-2013, 12:39 PM   #10
SigFTW
One upper arm has rivets instead of bolts holding the ball joint. I want to make them the same so once I start tearing down the front end, I'll look a replacing or cutting out the ball joint.
Old 05-09-2013, 01:37 PM   #11
ghettoluxury
ghettoluxury's Avatar
The ball joint with the rivets is still the original.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-09-2013, 03:33 PM   #12
Koffer
I hear you there . The new upper control arms also have the ball joints riveted .
I replaced the whole arm since I figured replacing the bushings, ball joints, rubber bumper plus cleaning and painting was going to be a long whole weekend project where swapping out the whole thing on both sides was about an hour.
Took just as long to get out the the tools ,clean up and put them back
Old 05-09-2013, 01:42 PM   #13
Tx Firefighter
Agree on riveted original.
If you need bushings, you surely need new ball joints too.
Old 05-09-2013, 01:47 PM   #14
SigFTW
It's hard to tell until I pull it apart, looks like some work was done and some pf the parts look newer. I'll check it all out once it apart and replace the ball joints.
Old 05-09-2013, 03:00 PM   #15
SigFTW
The more I start to fix something the more I want to tear it down and start from the ground up.
The engine is in great shape, rebuilt 350 with 30k. Runs very well after a tune-up.
This is my first rebuild and I want to keep it within a budgeted amount. May go over a little. So fare it's right on course.
Old 05-09-2013, 07:24 PM   #16
t5noel
I used an air hammer, it was ugly and difficult to replace the bushings. I'll never do it again. If I can buy new control arms already assembled I will go that route.
t5noel is offline   Reply With Quote
Old 05-10-2013, 02:14 AM   #17
74 stepside
74 stepside's Avatar
What I do is weld in some steel on the bottom of the arms to give it more strength before using a press. Plus it also helps keep the arms from getting bent when they hit the ground on lowered trucks.
74 stepside is offline   Reply With Quote
Old 05-10-2013, 06:27 AM   #18
Tx Firefighter
Very smart idea. That would sure help with the crushing issue when using a press.
Old 05-10-2013, 08:18 AM   #19
SigFTW
Good ideal!
Old 05-13-2013, 08:11 PM   #20
bluex
bluex's Avatar
You guys think $75 is a fair price to have both arms plated up like this? Dropped mine off to have them done today. I would do it, but the lowers are to big to sneak into work an i have no welder at home yet....
bluex is offline   Reply With Quote
Old 05-21-2013, 08:55 PM   #21
74 stepside
I dont think thats too bad. Most fab shops charge on average $75 hr.
Old 05-22-2013, 01:57 AM   #22
bluex
bluex's Avatar
Overall I'm happy with it, they could have done some clean up, but with a one day turn around I'm not complaining...
Slowly but surely I'm getting mine ready to go back together. Just have the lowers to clean paint an put new bushings in...
I hope to finish up next weekend....
Old 05-10-2013, 04:34 PM   #23
wraprail
wraprail's Avatar
X3 on the reinforcement. Think I will try that.
I been avoiding doing my lowers but its time. I have had the new lower bushings in my garage freezer for so long they are frozen in ice. I will have to defrose the frige to get them out.
If I find any new tips I will let you know.
wraprail is offline   Reply With Quote
Old 05-10-2013, 04:42 PM   #24
SigFTW
Do you normally keep bushings in the freezer if you store them for lone periods of time?
Old 05-10-2013, 06:13 PM   #25
wraprail
wraprail's Avatar
I put them in the freezer to make installation easier. They get a little smaller.
It helps.
I put them in there a couple days in advance of doing the job. ... That was 6 months ago.
Not looking forward to doing it
