Old 05-10-2013, 02:27 AM   #1
1972_GMC
1972_GMC's Avatar
Repair panel help...
Hey y'all,
I need help for one rusted area in my '72 GMC burb. I have all of the other panels lined out, but I am having trouble with this one spot. It is the floorboard area next to the wall (where a 4th door would be) in the rear drivers side passenger area. It is rusted out just like the fronts are at the rocker panels.
How have others here replaced this section of floorboard? It's not rusted too bad, but it will need to be replaced. Can this be fixed from the top or do you have to go in from the driver's side exterior? And is there a panel that can be fitted for this area, or will I need to fab one? Thanks!
1972_GMC is offline   Reply With Quote
Old 05-10-2013, 10:17 AM   #2
68GMCburban
68GMCburban's Avatar
Re: Repair panel help...
I'm having this problem as we speak. I'm not too sure what to do, hopefully somebody will have some ideas.
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
Old 05-10-2013, 11:03 AM   #3
tlcrz1972
tlcrz1972's Avatar
How about a couple of pictures to see what it looks like.
On my pickups that I had a similar problem I cut out the offending rust and made a cardboard template of what I needed it to look like. And then took the pattern and transfered it to the sheetmetal and then cut it out as needed.
Then go to a sheetmetal shop and get the metal bent as needed to fit. Be sure to leave it long going over the original floorpan so you can weld it in nicely.
tlcrz1972 is offline   Reply With Quote
Old 05-11-2013, 11:30 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
I am looking at the same repair.
From what I can see it will have to be done from below to separate the inner rocker from the pinch weld at the base of the quarter panel.
The rest looks like it can be done from above.
The inner door panel area looks like it passes by the inner rocker and may be spot welded to the rocker pinch weld and/or to the inner rocker. Won't know for sure until I cut it open or someone else has some pics of the process.
By cutting from above first and removing the material all the way to the door panel skin you can find out how it is put together and how it has to be repaired and what order things need to be reassembled.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-24-2013, 08:04 PM   #5
tlcrz1972
tlcrz1972's Avatar
Well I have a floorpan out of a suburban, I saved it for a future crewcab project. And I haven't decided if I'll use it or not.
But for you needing to see what it looks like off of the truck here are a couple of pictures.
If I can help let me know and I'll see what I can do.
I have more pictures if needed.
Old 10-30-2014, 10:09 PM   #6
1972_GMC
1972_GMC's Avatar
Sorry I took so long to reply, but thanks for the pics, that helped a lot!
