Old 05-10-2013, 09:23 PM   #1
ZombieWeinerDog
ZombieWeinerDog's Avatar
Fan shroud for big block?
Another thing i thought about before doing the big block swap, do i need to get a different fan shroud for a big block? right now its just a small block with a flex fan. i looked in lmc, and the only listings they have is for a small block. Any help would be appreciated.
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 05-11-2013, 05:06 PM   #2
ZombieWeinerDog
Re: Fan shroud for big block?
I should have asked this differently. What are all the other big block swaps using for cooling fans?
1972 longbed- 454
1967 shortbed- 355
Old 05-11-2013, 06:29 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I used factory big block shrouds on the two I converted. And a fan clutch and fan.
Tx Firefighter is offline   Reply With Quote
Old 05-11-2013, 08:23 PM   #4
c10srule
c10srule's Avatar
ive got a big block shroud from the truck shop and an 18" 7 blade fan off a chevelle, ive used small block shrouds but had to shorten them some and i always use the same fan, i look for the fans at swap meets and get every decent priced one i can,
c10srule is offline   Reply With Quote
Old 05-11-2013, 09:49 PM   #5
ZombieWeinerDog
I guess ill look for a big block shroud at some junk yards. Ill use the smallblock one for the time being.
1972 longbed- 454
1967 shortbed- 355
Old 05-11-2013, 10:08 PM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Yes, go with the BB shroud. I think I have a couple around here, let me know if you don't find one locally. Also , get RID of that flex fan and get a good GM heavy duty clutch fan!
Tom Vogel is offline   Reply With Quote
Old 05-12-2013, 12:35 AM   #7
ZombieWeinerDog
thats the plan.
1972 longbed- 454
1967 shortbed- 355
