Wood beed Conversion ?
I'm worried if i use the Rubber pads between the truck frame and the bed. That The bed will be to high and the lines wont line up.
To use or not to Use ? |
Re: Wood beed Conversion ?
Used them on mine, and it looks fine. You should be okay.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
![]() Join Date: Feb 2012
I am doing a steel to wood conversion. Is there any problems I may encounter? I have bought everything new for the conversion.
Did you get the "L" brackets to go down the inside of the bed to bolt yer wood to? You'll probably have to tackweld them in? Don't know if they can be bolted in. Got mine from Horky's truck bed parts. You can see the one attached in the pic. The rest are laying there, awaiting installation.
The inside floor angles are the same from the factory on the fleetside beds for either wood or metal floor. Why did you need to add them? The only reasons I can think of are rust or damage.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
