what kind of glue do I use for the weather stripping??
is there a special glue to use for the weather stripping on the cab on the inside of the door, my truck appears to have been glued at some point, the stripping looks good its just that the glue that was used seems like it gave out. Is there a special glue or can I just use gorilla glue??
![]() Join Date: Jan 2013
Re: what kind of glue do I use for the weather stripping??
Get some weather stripping glue, its at any auto parts store. Thats what its called. I just did this actually. Kinda a pain to hold it in place, but the glue is strong as heck
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
thanks for the answer, "wether stripping glue" very straight forward!! thanks!! I will probably use the blue scotch tape just to keep it in place.
![]() Join Date: Jan 2001
3M and Permatex both make weatherstrip adhesive, and both are good.
There are two kinds; one is yellowish and the other is black. I always use the black. |
![]() Join Date: Sep 2012
Ive been using the "3m weatherstrip adhesive" in the red and white tube for years and boy is it sticky. If you put on a bead, press it down then pull it back up for just 1 minute it will double stick. I can promise you it will stick, I use the yellow, but the black from above may work just as well!!
Quit if it's not FUN!!!
Affectionatly known as "Gorilla Snot"
Yep, thats what I used. Try and keep it off you.... I got some on my shirt, and a month later still cant get it off!
May be obvious but it hasn't been said, don't put all the adhesive on at once. Do a couple of feet, stick in the weather stripping, add more glue, then more strip, keep repeating. I went all the way around my trunk with glue and by the time I started to install the weather stripping, it was so gummy I couldn't even force it all the way down in the weather stripping channel. I had a helluva mess
Another item to use as a clamp on weather door strips installation...Clothes pins believe you can still get them at the Dollar type stores.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
