Old 05-18-2013, 12:29 PM   #1
rossboss
rossboss's Avatar
vent window rebuild
I installed a fairchild vent window kit with less than satisfactory results. Though the gasket fit well and seems to have some quality the division bar is a different story. It was way thicker than the oem division bar I removed and as a result the wing window won't shut.
Has anyone purchased the divsion bars that steele rubber sell. They're expensive and I don't want to buy with the same results as the fairchild bars. I might be forced to reinstall the stock ones. Anyones input with similar problems would be appriciated.
rossboss is offline   Reply With Quote
Old 05-18-2013, 02:36 PM   #2
Sharps40
Re: vent window rebuild
Same with LMC div bar - thick. After several weeks shut and a bit of disc brake greese things are workin a bit better but prolly still gonna have ta carve a bevel to ease the vent windows closed w/ havin to get out of the truck and use both hands.
Sharps40 is offline   Reply With Quote
Old 05-18-2013, 03:03 PM   #3
1966shortwide
lmc has kit ,#6 that has division bar felt ,fit's in your original bar , with glass run channel,and window seal. Since you got kit already, don't know if you can buy d bar felt separate. Remove old felt and install felt fit's perfect, i siliconed mine in. 1964 1966 kit is # 38-5995
1966shortwide is offline   Reply With Quote
Old 05-18-2013, 07:20 PM   #4
rossboss
rossboss's Avatar
Thanks for your input 1966shortwide but it's actually the wing window I'm referring to, the one that pivots. The seal that atatches to the back side of the run glass channel is to thick and doesn't allow the vent glass to shut completely.
Old 05-18-2013, 09:34 PM   #5
jbgroby
jbgroby's Avatar
AND this is why I'm saving up to buy the all in one pre-made replacements. I just don't have what it takes to rebuild mine. I not going to use mine.
jbgroby is offline   Reply With Quote
Old 05-19-2013, 05:58 AM   #6
Sharps40
Agreed... on the LMC Kit, The felts and fuzzies and window channel for the doors are about perfect. The arched rubber gasket for the vent window is fine too. Its the vertical rubber strip/division bar that gets riveted on to the vertical section of the vent window that is too thick and causes the problems.
Old 05-19-2013, 09:08 AM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Does anyone send this kind of feedback to LMC? We are the best test drivers out there and they should know the issues we have with their products.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-19-2013, 11:08 AM   #8
1966shortwide
oh, i did not read correctly, dah, dah, ,anyway i've not replaced mine yet so don't know on that part , is the seal visibly thicker than the old one ,laid side by side . like sharps 40 said all other seals and component's are perfect.
Old 05-19-2013, 11:27 AM   #9
gmcdeadhead
gmcdeadhead's Avatar
i saved up for good used ones with good rubber and glass , i think it's the only way to go.
gmcdeadhead is offline   Reply With Quote
