Old 05-20-2013, 07:51 PM   #1
bohmankid
bohmankid's Avatar
brakes spongy after swap
Anybody else having problems? I put the 5.3 vortec in my 85 gmc 4x4. I have a vacuum coming off the manifold into the brake booster, transmission, and heater controls.. My brakes are very spongy, I thought I read somewhere that these motors don't put out enough vacuum. input?
bohmankid is offline   Reply With Quote
Old 05-20-2013, 08:16 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: brakes spongy after swap
They should put out plenty. When I installed my 22x/23x@.050 cam'd 6.0L and 1st fired up in my truck, it was set up with a carb and intake, with 6LS MSD box firing coil packs. Vacuum was good (15"-17") even with the cam. Swapped everything over to OEM EFI intake and ecm/tcm controlling everything with a custom harness. Vacuum fell to like 10"-12" and my brakes went to crap. Almost no boost from the power booster, with it occasionally working since I have a vacuum storage tank in line, which was capturing a little on vacuum on deceleration.
anyway....after plugging everything and then swapping the throttle body, new intake, verifying injectors, and more with no real change...I asked my tuner if it could be in the tune and could he do something. He said sure and changed one of the idle/air tables and made another 2"-3", finally powering the brake booster. I'm hoping an upcoming tune (different tuner) will resolve it all together, finding the 15"-17" of vacuum my motor made when 1st installed.
I'd run the brake booster "independently" off the back of the manifold and pull the vacuum for everything else from another port.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-20-2013, 08:31 PM   #3
bohmankid
bohmankid's Avatar
What's the best way to open up one of those other ports on the manifold?
I'm also gonna make sure I don't have a vacuum leak cuz the manifold gaskets are original. But my check engine light isn't on, so I assume no vacuum leak.
Old 05-20-2013, 08:44 PM   #4
85burb
85burb's Avatar
Are they spongy or hard to push? Hard to push would possibly be a vaccum issue but spongy that is a air in the break fluid issue.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-20-2013, 09:04 PM   #5
cableguy0
As stated above spongey brakes would be air in the lines,bad master cylinder or a leak somewhere. Hard pedal would be booster problem due to low vacuum. A stock ls is going to make plenty of vacuum to run power brakes. Check the wheel cylinders,hoses,calipers,lines and master cylinder. Unbolt the master cylinder from the booster and check for wetness behind it.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-23-2013, 04:17 AM   #6
crazy longhorn
Fabricate till you "puke"
Checkin for the wet spot....I probably should not say any more..... Best of fun on your travels, I have found that a house is better to live in, than a truck(been around a few yrs)? AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-20-2013, 10:38 PM   #7
68GMCCustom
If you're talking about an OEM plastic one. The rear brake booster port has to be punched. The side port had a tab to twist/cut off? Not sure about front port by throttle body. And yes.....my pedal was HARD...not spongy.
Kurt -
Old 05-20-2013, 10:42 PM   #8
85burb
85burb's Avatar
The small tab on the side of the plastic intake I carefully twisted the flat part off the end with pliers. If you had a tiny saw blade you could cut it off.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-21-2013, 02:35 AM   #9
bohmankid
bohmankid's Avatar
Thanks guys I didn't even think about that. I'll check fluid/leaks/air and all that tomorrow. And yes, it's spongy, almost touches the ground. And my brake light is on.
